Old 02-27-2011, 01:13 PM   #1
boss351
Default olds 442 w-30 stocker
hi folks ,i have a question, in 1970 a w-30 olds ,which class this car can it run in category stock ,i know than in 1966 the big 442 olds can run b/stock ,it is the same with a w-30 1970 olds or what is the best class the w-30 can run ,thanks
boss351 is offline   Reply With Quote
Old 02-27-2011, 02:17 PM   #2
Dusty Lowell
Dusty Lowell's Avatar
Send a message via AIM to Dusty Lowell
Default Re: olds 442 w-30 stocker
looks like D, E, F but i could be wrong...
Dusty Lowell
#1773 STK F/SA
Dusty Lowell is offline   Reply With Quote
Old 02-27-2011, 02:50 PM   #3
Future Stock
Which class would they have run in 70-72?
Future Stock is offline   Reply With Quote
Old 02-27-2011, 03:07 PM   #4
Paul Ceasrine
Liked 10 Times in 10 Posts
The 1970 Olds 4-4-2 455/360 HP in 1970 would run G/S.
The 1970 Olds 4-4-2 455/370 HP in 1970 would run in F/S.
Those classes were from 1970/1971.
The cars weighed in at around 3675 lbs.
In 1970 at Dallas, the 1970 Olds 4-4-2 W-30 ran in F/Stock.
And the National Record was 12.01
Old 02-27-2011, 04:31 PM   #5
boss351
thank ,Paul ,so it's impossible to run a stock 455 motor , only with headers and slick with a 442 w-30 ,4 speeds and 3.91 with a spectacuar run at 11.79 ,what do you think about that .
Old 02-27-2011, 04:39 PM   #6
boss351
hey ,Paul ,, also why olds run in 66 run b/s and olds run f/s in 70
Old 02-27-2011, 05:13 PM   #7
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
just to chime in ,,you would be hard pressed to run that # ,but there is a racer who runs a green 70-71 olds with a 4 speed set up (350 i think ) that could give you some insight on what you need to do with your car i dont have his info but he runs division 1 ,,if i can find the info i will repost gmonde
Old 02-27-2011, 06:10 PM   #8
bigshow2966
Liked 181 Times in 56 Posts
Talking Re: olds 442 w-30 stocker
Isn't Bureski's W-30 in E/SA?
bigshow2966 is offline   Reply With Quote
Old 02-27-2011, 06:10 PM   #9
Mike Brogniez
Would it be S Murray.............
MB
Name:	Numidia Jul 23-24 012.JPG
Old 02-27-2011, 06:23 PM   #10
Paul Ceasrine
Boss351,
The weight break factors changed over the years.
Oldsmobile 4-4-2
as per year
1965,,,,,,B/S
1966,,,,,,C/S
1967,,,,,,B/S
1968,,,,,,D/S
1969,,,,,E/S
1970,,,,,F/S
It fell into the 9.50-9.99 wt/hp from 1968 and up.
In 1965, 1966, 1967 the class wt/hp was 9.50 - 10.59
Super/Stock
1967,,,SS/E
1968,,,SS/F
