Old 03-27-2011, 07:28 PM   #1
ronn brigham
Default Racing Slicks
Am running a B-Sitck '69 Nova big block. Am looking to buy new set of slicks. Not sure which manufacturer is best to buy, the circumference to get and the compound to use? Currently using Hoosier 30 x 9 x 15 and D07 compound. Wondering what people are running and would suggest I try using.
ronn brigham is offline   Reply With Quote
Old 03-28-2011, 02:23 AM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Racing Slicks
Long life, consistent and fast...hard to beat M/T 29.5" x 9" "S" for stiff sidewall (stick slick).
Jeff Lee 7494 D/S '70 AMX
Old 03-28-2011, 04:47 PM   #3
REGGIE WINKLES
Liked 39 Times in 9 Posts
Jeff is correct, the Mickey "ST" works great with a stick. I tried Hoosier's once and they worked good.......for about 15 runs, then they would never hook.
Reggie Winkles 2650/Stock
REGGIE WINKLES is online now   Reply With Quote
Old 03-28-2011, 05:51 PM   #4
Stick Racing
3056ST
________________________________
Andy Stone A/S 1102 SS/C 1112
Stick Racing is offline   Reply With Quote
Old 04-24-2011, 11:34 AM   #5
brent flynn
brent flynn's Avatar
I run 9x30 Pheonix's... i dont run a stick, but i dont run the radial slick...
I would give them a call and see what they have for you... i was doin 1.48-1.49 60fts with mild 455 combo in my 68 bird at full race weight of 3550 leavin at 2000 on footbrake...Caltracs on rear, front suspension all stock, not even trick springs... I put 150 passes on them, check holes were about gone and they were still hookin when i took them off...
