Old 04-18-2011, 07:38 PM   #1
HawkBrosMav
Liked 302 Times in 73 Posts
Default CJ C-2 transmissions
Are they available to buy outside of owning a CJ? thinking about a bracket car combo and want to keep it all Ford products no more powerglide.. not that it really matters..they're probably identical.. just thought it'd be cool to have one...
Old 04-18-2011, 08:14 PM   #2
Wayne Kerr
Liked 26 Times in 11 Posts
Default Re: CJ C-2 transmissions
Reid Racing
2 pc. case with removeable bellhousing
Wayne Kerr is offline   Reply With Quote
Old 04-18-2011, 09:49 PM   #3
Chad Rhodes
it IS a powerglide
Chad Rhodes 2113 I/SA
Old 04-19-2011, 12:59 AM   #4
HawkBrosMav
have either of you actually seen one or are you just throwing useless info? any CJ guys out there no for sure?
Old 04-19-2011, 02:18 AM   #5
Look familiar?
Old 04-19-2011, 08:15 AM   #6
Ultimate Converter Concepts
Sponsor
Ultimate Converter Concepts's Avatar
Liked 59 Times in 12 Posts
It is a PG with a Ford bell. I designed the first 3 proto type converters for them. Ford front mounting cover, from there back all GM.
Lenny Croteau
www.ultimateconverter.com
Phone 704-892-6837
Ultimate Converter Concepts is offline   Reply With Quote
Old 04-19-2011, 09:57 AM   #7
HawkBrosMav
Thanks guys I figure that's what they were but couldn't find a pic like the one Mark posted. since I already have one makes it a lot easier to consider this project.
Old 04-19-2011, 02:44 PM   #8
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Great information....
I went to my rulebook and in the Stock Eliminator, Drivetrain Section Transmissions, Automatic I found that "NHRA-accepted adapter plates permitted" and would possibly allow me to run a 904 Torqueflite behind my Pontiac engine.
I went to the NHRA website to look in the Accepted Products section for an adapter for a Pontiac Engine to 904 Torqueflite transmission. There isn't a section in the Accepted Products identified as "NHRA-accepted adapter plates"
Ther are no adapters listed so either all adapter plates are legal or no adapter plates are legal
I guess that it might be located in the East Coast on-line version of the NHRA rulebook.
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 04-19-2011, 04:20 PM   #9
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Whatever rule book, just run a Pro trans and you will have your 904.
Bob Pagano A/SA
Old 04-19-2011, 04:45 PM   #10
Bob Mulry
Bob Mulry's Avatar
But the difference is that one of them is built in a stock 904 case and costs X amount of dollars and the other is a 904 built inside of a TH350 and it costs XXX dollars.
Neither is cheap but one them costs about 3 times as much as the other...for the same performance!!!
Bob
PS: I have no axe to grind with the Smith's...good people who build fast cars and transmissions...even raced against them in the same class 30 years ago.....
Bob Mulry 7516 STK
A & M Motorsports
