Old 04-19-2011, 11:43 AM   #1
67champ
Liked 4 Times in 2 Posts
Default Front Coil Spring Life Expectancy?
I have heard that front coil springs should be changed (swapped out for new) every 3-4 seasons, others say they have used their springs for over ten years, and car still works well. Application is 12.50 second 1967 camaro SBC. What say you?
Thanks,
dt
67champ is offline   Reply With Quote
Old 04-19-2011, 12:09 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Default Re: Front Coil Spring Life Expectancy?
I have had the front springs in my camaro for over 10 years. They are Moroso's They probably need to be changed now. I will go with the Santhuff springs when I change them. The car is sitting a little lower on the passenger side . Lots of miles in the trailer probably caused it. The car is still working as good as always. I cant see any need to change springs unless there is a problem with them.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 04-19-2011, 01:01 PM   #3
Bob Verwold
Bob Verwold's Avatar
If it ain't broke, don't fix it..................
Bob Verwold is offline   Reply With Quote
Old 04-19-2011, 01:05 PM   #4
Run to Rund
Liked 54 Times in 27 Posts
The Moogs I have used were good for years, no sag. The Morosos I used sagged considerably over the years.
Old 04-19-2011, 02:40 PM   #5
Jim Kaekel
Liked 535 Times in 110 Posts
Like anything else, I think there are several things that affect the life of the coil spring. Car weight, spring rate and diameter, length of suspension travel, wheelies, etc. I've had to replace mine about every five years or so, but that's on a nose-heavy Olds 4-4-2. I know the lower the nose is, the better the car works. But, of course a little goes a long ways and it's no good to have the worry of tearing your headers up either. My .02.
Jim Kaekel 3836 STK
Old 04-19-2011, 04:11 PM   #6
Jeff Lee
Jeff Lee's Avatar
An air pillow under the front cross member when traveling will ad years to your front suspension. It's the trailer rides that kill it, not the racing.
Jeff Lee 7494 D/S '70 AMX
Old 04-19-2011, 08:08 PM   #7
67champ
Thanks guys, looks like the early votes are in, and it's unanimous... I see no reason why I would have to replace my front coil srings anytime soon...
dt
