Liked 7 Times in 4 Posts
I am having trouble using the class guide to figure out what class my car would fit using the 1970- 383 (304hp rating) GT motor with OEM heads for fresh air package.The car is a 68 Dart set up for SS with either hood, GTS or hemi.
Thanks |
Liked 328 Times in 80 Posts
I think the hemi or even a plain jane 318 trim car is a natural D car @ 3055 lbs. and could drop to C weight @ 2905 or add and run E @ 3210. I think the GTS package is natural F @ 3365 can run E @ 3210 or G @ 3520. Might want to get this verified, I think it's right maybe Travis can check it when he gets back from Joliet.
Ernie |
Liked 601 Times in 213 Posts
I don't see where you got the 304 HP rating? With OEM heads, the GT Rating is 300HP. With replacement heads, the HP is 309. That would put the OEM engine in GT/EA with the fiberglass components, and GT/FA with the GTS body. With the replacement heads, it would fit in GT/DA and GT/FA.
Shoulda stayed away, right Will? LOL
Ed Wright 4156 SS/JA |
#6 | |
Thanks for the help. |
Liked 327 Times in 121 Posts
70 383 is 304HP in GT, I'm doing the same motor, which will power my Sport Fury until the Challenger is done.
You are correct, and I was wrong. I now see where the 1970 - 383 is 304 HP with the oem heads, for GT. That would put a 1968 lightweight in GT/DA and a GTS in F.
Thanks for all the info everyone. Now one more question. How did you determine the DA or FA classification. Type slow as I am old!
Liked 70 Times in 22 Posts
Will
You can't just run the 68 hemi Hood. You have to claim the 68 hemi body to run the hood and that includes a lot of other things. The fenders, window straps and on the Dart it is a different wheelbase than a stock Dart. This all depends on the job tech does. Your base weight would be 3020. DA would be 304 x 9.5 + 170 = 3058. FA is 10.5 x 304 + 170 = 3362. Think they round down to the closest 5lb. You might check my math but I think its right.
Stewart Way 2424 SS |
