Old 07-03-2011, 10:59 AM   #1
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Question Coil Location
This is a two part question.
1. - Coil location preference in a stocker application; under hood vs. interior??
2. - If you prefer the interior option, would you use the MSD style bulkhead fitting or a continuous coil wire routed through a grommet?
Thanks everyone and hope you're enjoying the CanadaDay / Independence Day festivities!!
Dave Turner
SS/GT #1153
Old 07-03-2011, 01:17 PM   #2
rick lester
Liked 4 Times in 1 Post
Default Re: Coil Location
Dave, with a Ford distributor being on the front of the motor, I personally would mount it up front on the core support or the fender apron. If the distributor was on the back of the motor, ie; Chevy, then I could see mounting in the interior but even then thats alot more work than needed, in my opinion. My thinking on this is shorter wires mean less problems.
rick lester is offline   Reply With Quote
Old 07-03-2011, 01:33 PM   #3
Dragsinger
Liked 99 Times in 60 Posts
Dave, if you pass through the firewall be sure the coil wire fits loosely in the grommet. That is to say, grommet ID slightly larger than coil wire OD.
Also, what about the coil primary wires? Is the ignition controller already mounted inside the car? The primary wires need to be separated from the secondary wire.
Larry Woodfin 471W
Old 07-03-2011, 03:08 PM   #4
Dave Turner
The ignition box will be inside the car; (once I finish the install). I planned to run the coil primary wires through a separate port.
Thanks Larry.
Dave Turner
SS/GT #1153
Old 07-03-2011, 04:10 PM   #5
GTX JOHN
We had many headaches with MSD Bulkhead connector.....it would arc to
ground. MSD does not advise it anymore on Drag Appliciations.
Hats off to those who have given so much so that we still are free and can celebrate the 4th tomorrow !
Old 07-03-2011, 04:24 PM   #6
Greg Reimer 7376
Liked 719 Times in 220 Posts
Right,John!! And let's vote the rest of them out so we can stay free!!!
Old 07-03-2011, 04:29 PM   #7
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
Talking Re: Coil Location
Hey Dave, I vote for under hood on stocker. I just came back from Norwalk Nat'l event and many stockers have it under hood on firewall, I looked at many, trust me.
Old 07-03-2011, 04:37 PM   #8
Dick Kirkpatrick
I would put it as near to the distributor as possible, keeping in mind to locate it away from extreme heat sources.
I think Venice had his mounted on the front motor plate.
Dick Kirkpatrick 3033 SS
Dick Kirkpatrick is offline   Reply With Quote
Old 07-03-2011, 11:25 PM   #9
Dave Turner
Wink Re: Coil Location
Dick, great idea....I'll mount it on the motor plate!! Jackmule!
Dave Turner
SS/GT #1153
Old 07-03-2011, 11:27 PM   #10
Dave Turner
Smile Re: Coil Location
Thanks Tim; keeping it simple is probably a good thing.
Dave Turner
SS/GT #1153
