Old 07-07-2011, 09:35 AM   #1
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
Default Dodge Dakota racers?
Does anybody make a 5 bolt front hub for these trucks? I am putting together a 99 Dakota for a customer and he would like to change it to 5 bolt wheels.
Thank you,
Larry
Larry Curtis is offline   Reply With Quote
Old 07-07-2011, 10:40 AM   #2
Phillip marvetz
Phillip marvetz's Avatar
Default Re: Dodge Dakota racers?
Yes, The early Dakota's had 5 lug rotors. Bruce Flodin in Div6 has converted his truck.
2009 V/SA Record Holder
Old 07-07-2011, 11:33 AM   #3
Larry Curtis
Unfortunatly those only work up to 96. the newer ones have a differant hub and spindal.
Old 07-07-2011, 01:25 PM   #4
FED 387
Liked 336 Times in 183 Posts
not sure but a guy in my area did one a while back like 4-5 years ago--he said he used 2002 Dodge RAM 1500 (1/2 ton) Pick up hub--also told me that he was told that Dodge NITRO and certain Jeep Liberty hubs will also fit ---ya end up with about a 3/16-1/4 inch offset difference than with a "stock" Dakota wheel towards the inside of the wheelwell--- he then used F150 ford rotors---cant remember the year tho instead of redrilling his original rotors from 6 to 5 lug didnt want to go thru the hassle and maybe have problems with his brakes---however he did have to modify the Ford rotor a bit either the total outside diameter of the rotor or the inside register hole---hope this helps--comp
Old 07-07-2011, 05:25 PM   #5
magnumv8
All I did was send mine to MOSER and they redrilled and tapped mine to the standard MOPAR 4 1/2" bolt pattern for me....I then used 1/2-20 3" studs and Loctite Red to glue them in.....this has been in service along time and has given me no problems whatsoever.....
D L Rambo....
magnumv8 is offline   Reply With Quote
Old 07-10-2011, 11:31 AM   #6
Jeff Teuton
Liked 325 Times in 50 Posts
Knock out the 6 and get a machine shop to redrill 5 on either 4 1/2 or 4 3/4 bolt circle. I assume this is a street truck.
Jeff Teuton 4022 STK
