Old 08-13-2011, 11:59 AM   #181
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Default Re: Some "Dime Rockets" for the 4TH!
Can anyone tell me what the natural class a 16.52 lbs/hp car falls into ?
And, what is the next slower class down is ? Is it 17.0 or 17.5 lbs/hp ?
I don't have an NHRA rulebook.
I found the 91 Lincoln MKVII is eligible and it uses the Mustang 5.0 engine.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 08-13-2011, 12:02 PM   #182
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Weight breaks for all NHRA and IHRA S/SS classes:
http://classracer.com/classes.html
Old 08-13-2011, 03:32 PM   #183
ALMACK
ALMACK's Avatar
Thanks Mike !
I see a 1995 Town Car Cartier could technically run U/SA......hmmm......
I/PS '95 Mustang GT
Old 08-13-2011, 04:13 PM   #184
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Originally Posted by ALMACK View Post
Thanks Mike !
I miss spoke, the car is actually a 1994 with the 4.6....
The question I have is the 4.6 capable of making this 3800 lb behemoth run under the index. I can get the car for nothing or next to it...
What would it take to get under index. Gears, convertor... WHere would you get some headers ?
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
Old 08-13-2011, 05:15 PM   #185
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Any of the guys that build headers, even Billy could do it ! But they will need the car to do the job.
Bob Pagano A/SA
Old 08-13-2011, 07:34 PM   #186
ALMACK
ALMACK's Avatar
Your 94 could run :
......Q/SA @ 3570 w/driver.
Or, R/SA @ 3780 ( natural class)
Or, T/SA @ 3990 lbs.
This engine has me wondering.
I saw another thread about the 96-98 Mustang GT and I do not know the differnce between the 94 Lincoln 4.6 and the 96-98 Mustang 4.6.
Anyway, the concensus of the thread was that the 96-98 Mustang makes a good Pure Stocker. Not sure about an NHRA Stocker tho.
Not sure on this, but I was thinking the '90-99 Town Car was based on the Panther chassis. (Crown Vic)
If so, then there is where you would look for headers.
I/PS '95 Mustang GT
Old 08-13-2011, 07:51 PM   #187
Robert Swartz
Robert Swartz's Avatar
Your 94 could run :
Problem with IHRA pure stock. The weight breaks stop at I/PS, which is a 16.00 break. This car is way above that. These engines "should" be basically the same as the 96-98 Mustang? This is the 2 valve engine. Ford went to the 3 valve in 1999, I believe.
As my partner Tod says, "we can probably get the car for next to nothing". If we can't do anything with it. I'll just strip it out and sell the shell for scrap.
Yeah, it would at the least need headers, a converter and a posi unit and some gear. I have a set of wheels, just need a set of front tires and a set of slicks. If we end up with it, probably just do a simple tune up on it, check over for safety, brakes and such. Just take it to one of the local strips, see just how far off it is. I'll take it somewhere and weigh it first. Give me an idea of what we're up against.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 08-13-2011, 08:07 PM   #188
ALMACK
ALMACK's Avatar
Robert:
I knew the Town car was not a good choice for IHRA Pure Stock.
As an NHRA Stocker or IHRA EFI Stocker I would think the TCar would need a 4.56 gear, a 4000 + stall , lightweight wheels/tires, lightweight brake rotors, electric fans, and special long duration cams. I would say that 2V could rev, so that would be the key.
You ought to try the combo and let us all know if the car gets close to the index.
I/PS '95 Mustang GT
Old 08-14-2011, 08:51 AM   #189
Billy Nees
Liked 7,812 Times in 1,748 Posts
Looks like a few of you have done some detective work on this Lincoln and I'd say "Go for it!". It really can't be a bad combo, if it fits T it should run the index. How fast will a Pure Stock Mustang go?
Billy Nees 1188 STK, SS
Old 08-14-2011, 10:43 AM   #190
Robert Swartz
Billy,
Hinges on how little we can get the car for. Have to chuckle a little here, just never thought of a 4 door Lincoln as a "race car"! If we do this, correct me if my initial thinking is wrong. I figure the minimum I need to run the car, headers, I haven't researched this at all. Does anyone make headers for a Lincoln? Get a posi unit, if the car doesn't have one, or a mini-spool. A gear set, this has an 8.8, as suggested by Almack, a 4:88 or deeper gear, suggestions for a 4000 lb car? As mentioned, I have a set of wheels. Anyone in the Indiana-Kentucky-Ohio area got any old used fronts or slicks with some life left in them that you don't want to retire off of, LOL!That'd be enough for me to take it to the track.
