Old 09-02-2011, 11:27 AM   #1
gearjammer9025
Default Back spacing
A little while back I asked about putting a 10" rim on a 1969 camaro 4 speed running G/S. I was wanting to know if anyone knows the correct back-spacing that i need. I saw here on class racer.com a picture of a 1969 camaro running G/S that had a 10" rim. Or if anybody that has this car an same rim size any info wood be greatly appericated. I figured that some body up here has got to know.
gearjammer9025 is offline   Reply With Quote
Old 09-02-2011, 11:57 AM   #2
Mickey Whaley
Default Re: Back spacing
5 1/4 backspace 10' RIM FIT ON MY 69 Stocker
Mickey Whaley is offline   Reply With Quote
Old 09-07-2011, 07:51 PM   #3
gearjammer9025
Thanks Mickey for the info. I guess now the only thing is to do it to order some rims. Im hopeing that more tire will be on the ground to help lower 60 foot time. It just seems to waud the tire an spin more than it should. I mean a stick car is gone spin a little right. I guess im thinking right. O an dont worry bout the missed spelled words.
Old 09-08-2011, 05:05 AM   #4
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
You may be very limited in rim manufactures that offer a 5 1/4" back space on a 10" rim.
Just a heads up.
Old 09-08-2011, 10:50 AM   #5
Run to Rund
Liked 54 Times in 27 Posts
Where are you? I have some 5" BS Marsh light steel wheels (about 19 lb each) you could try or buy, 4.75" bolt circle. Note also that the 10" wheel will let the tire grow about .4" in width at the sidewalls vs. an 8" wheel.
Old 09-08-2011, 10:56 AM   #6
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Back spacing
Just a heads up.
Hole Shot Wheels will make any back space you want. Check them out. Jim
http://holeshotwheels.com/
Jim Wahl is online now   Reply With Quote
Old 09-08-2011, 01:11 PM   #7
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Clutch HAS A LOT to do with setup. What type you running?
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 09-09-2011, 07:42 PM   #8
gearjammer9025
I live about an hour from Raleigh NC. The clutch is a Mcleod an its the Sintered iron disc. With the adjustable pressure plate. Calvert 9 way adjustable shocks on the back. Caltracks also.
