Old 11-23-2011, 11:39 AM   #31
67 Post GS
67 Post GS's Avatar
Liked 49 Times in 11 Posts
Default Re: New Kid
Very nice!
67 Post GS is offline   Reply With Quote
Old 11-23-2011, 12:56 PM   #32
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Default Re: New Kid
That car leaves great.Looks good too. Best of luck with it!!
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 11-23-2011, 09:37 PM   #33
Phillip marvetz
Phillip marvetz's Avatar
Default Re: New Kid
Originally Posted by older racer View Post
as a 71, it requires the shark tooth grille. the 72 can run either grille.
Why would you not be required to use the correct grill in a 72?
Also did anyone catch the marker light in quarter?
2009 V/SA Record Holder
Old 11-23-2011, 10:58 PM   #34
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Re: New Kid
Well the car is 72 running as a 71. I run my 71 demon as a 72. No one ever said any thing about marker lights to me.
The duster came with to different grill in 72 I think.
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 11-24-2011, 02:10 AM   #35
older racer
Liked 68 Times in 26 Posts
Default Re: New Kid
hi, in 1971 the 340 duster came with the shark tooth grille standard in 340 cars. in 1972, the shark tooth and the standard grille were used in 340 cars. also, in 72 they had a twister with 318 and shark tooth grille.
years ago, a friend converted his 70 duster to a 71, he changed intake and carb and the grille.
older racer is offline   Reply With Quote
Old 11-24-2011, 02:10 PM   #36
Phillip marvetz
Default Re: New Kid
The duster came with two different grills in 72 I think.
The car appears to be a 70 or 71, The 72 has a different tail light panel so you can't claim a 72 as a 71 unless you cut out the whole panel. I have never seen a 72 340 car with a standard grill either. As for the Twister package cars they were available with the slant six also, I have one in the garage. There are photos of it in my profile.
The photo's also show the whole spare tire well cut out, Is that allowed or did he replace it with a correct floor?
Old 11-24-2011, 04:52 PM   #37
dartman
dartman's Avatar
Default Re: New Kid
You are right,the light are longer.are they that picky about the tail light?
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
Old 11-24-2011, 09:20 PM   #38
7172 duster
7172 duster's Avatar
Default Re: New Kid
Study the picture closer it has 1/2 of the new one installed
7172 duster is offline   Reply With Quote
Old 11-24-2011, 10:24 PM   #39
Jeff Lee
Jeff Lee's Avatar
Default Re: New Kid
Nice car. I wouldn't worry about the '71-'72 trim items unless NHRA tells you to change something. This 'aint the old days.
Jeff Lee 7494 D/S '70 AMX
Old 11-25-2011, 01:51 PM   #40
Phillip marvetz
Default Re: New Kid
Thanks, I couldn't tell for sure what that sheet metal was. Good luck with it.
