#1 | |
Liked 68 Times in 41 Posts
The duster came with to different grill in 72 I think.
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay Last edited by dartman; 11-23-2011 at 11:04 PM. |
Liked 68 Times in 26 Posts
hi, in 1971 the 340 duster came with the shark tooth grille standard in 340 cars. in 1972, the shark tooth and the standard grille were used in 340 cars. also, in 72 they had a twister with 318 and shark tooth grille.
years ago, a friend converted his 70 duster to a 71, he changed intake and carb and the grille. |
#3 | |
The photo's also show the whole spare tire well cut out, Is that allowed or did he replace it with a correct floor?
2009 V/SA Record Holder |
#4 | |
You are right,the light are longer.are they that picky about the tail light?
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay Last edited by dartman; 11-24-2011 at 04:56 PM. |
#5 | |
Nice car. I wouldn't worry about the '71-'72 trim items unless NHRA tells you to change something. This 'aint the old days.
Jeff Lee 7494 D/S '70 AMX |
Thanks, I couldn't tell for sure what that sheet metal was. Good luck with it.
Nice job on the build, looks and leaves great. Would you mind sharing how much ballast you're running? We're in the middle of building a 72 for F/SA as well...
Thanks, Tom
Tom Monte 151M |
#9 | |
We have about 160 lb. ballast with 50 lb. near rear bumper , the remaining is over the rear axle
#10 | |
Other ballast goes in the front seat.
