Old 11-27-2011, 07:50 PM   #1
csjta
Default Do I need a parachute?
Since NHRA is coming back to my area, I just want to make sure my car will pass tech
I Bracket Race the car, that's it. So I will be Bracket Racing in the No Electronics Class at VMP
The car in current trim runs in the 9.70's at 138 mph
I have Cage, Window Net, Full Face, Gloves, Neck Collar and Suit. I do not have a NHRA License and the Cage is not certed
I'm guessing I will need those also?
Thanks
csjta is offline   Reply With Quote
Old 11-27-2011, 08:38 PM   #2
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Default Re: Do I need a parachute?
Thanks
No chute (would apply if running 150) but you'll need the license and certified cage. Got a diaper? SFI damper, shield/bellhousing ? At least a SA2000 helmet? Etc?
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-27-2011, 09:03 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Do I need a parachute?
Gotta be at least a SA2005 now. (as of 01/01'2012). Jim
Old 11-27-2011, 10:16 PM   #4
csjta
Looks like I'll need a Diaper, License and Cage cert, I have everything else
Not too bad
Diaper Manufactures , can someone point me in a direction here?
TIA
Old 11-27-2011, 11:57 PM   #5
THE LEGEND
Diaper- Call DRE.
I'll bet you need a chute. You should need everything that S/G needs
Chip Johnson
THE LEGEND is offline   Reply With Quote
Old 11-28-2011, 01:41 AM   #6
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Originally Posted by THE LEGEND View Post
Diaper- Call DRE.
Chip Johnson
You don't need a chute unless you go over 150 MPH and may not even need a diaper. Depends (no joke intended) on the track. 9 second bracket cars here in the Pacific N/W aren't required to have a diaper. (yet)
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 11-28-2011, 01:49 AM   #7
Phillip marvetz
Phillip marvetz's Avatar
Not too bad
TIA
Or slow the car down to run 10's and save a bunch of $$$$
2009 V/SA Record Holder
Old 11-28-2011, 09:19 AM   #8
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
I think ever one should be required to have a diaper. I know a lot of people don't want to hassel with one, But having wrecked a car after getting in oil put out by the car in front of me makes me feel that way. Spend 20 to 25 thousand dollars fixing your car because you wrecked because of someone elses will change your mind in a hurry. Also, how many times have you been at a track and there has been a lot of down time while they are cleaning the track after someone has oiled it down. Thats one of the biggest reasons I don't bracket race much any more. Way too much down time from clean up.
Chuck
C and W Racing is offline   Reply With Quote
Old 11-28-2011, 10:12 AM   #9
csjta
I've thought about that too, still an option...
Old 11-28-2011, 10:46 AM   #10
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Do I need a parachute?
Csjta,
You have a PM...
Dave Ribeiro 1033 STK
