#11 |
The C5 Z06 does not have Ti rods, Ti intake valves, , CNC heads, or dry sump. The C5 Z06 has powdered metal rods, hollow stem steel valves, as cast unported heads, and internal pump wet sump.
#12 | |
#13 |
Banned
I forgot that was a C5 not C6
#14 |
Liked 225 Times in 88 Posts
Your in D-3 have you talked to Paul Booster he runs a nice red vette with front mount trans. and solid rear set up . Its fast and goes rounds , he won the dutch race at maple grove 2 years ago . I wouldn't run the IRS with trans its a sports car deal and you will blow it up . I think you can go with block mount bell , clutch and trans.(G-force or Gerico) and solid rear . It is a faster set up too . The Z06 is a nat. AA/s stick only car I think .So I was looking at the less HP combo with automatic . But its out of my buget for now . Good luck and I hope you build one totally cool car .
#15 |
Liked 3,247 Times in 987 Posts
Best advice I've seen in a long time!
#16 |
Nope. C5 z06 is not dry sum, no it rods, no cnc heads. You don't know what you are talking about. You are however correct on the 06 up cars. The 01-04 Z06 were 5.7L LS6, the C6 is 7.0L (427) LS7 505hp with the dry sump, ti valves and rods, and cnc heads
Chad Rhodes 2113 I/SA |
#17 |
Banned
#18 |
My apologies
#19 |
The rulebook does allow for moving the tranny up front, but i have heard that the car doesnt hook as well. Plus, the cost of moving it would be astronomical!
But then, if I wanted to race for cheap, then I should choose something besides a 'vette!! |
#20 |
This really caught my eye when you asked this question. I love a corvette the old an new modle's. So I did a little research an found a cople c5 an c6 corvette's running in stock. Jonathan womack runs a c6 a/sa an paul boster c5 d/sa an al corda in c5 c/sa. These guys could probably help you out the most. I dont have any contact info. this. I seen a couple video's on youtube an theses cars leave hard. Wheels up. Hope this helps.
