#21 |
Liked 8 Times in 7 Posts
#22 |
Banned
Liked 235 Times in 110 Posts
Correct-A-Mondo............Alan is 1000% correct......brush up on your stocker racing history. Remember the Crane stamped steel rocker that came in 1.6 for the small block chevys. Several big name stocker racers were DQ'ed many years ago by NHRA for using these even though the lift checked correct at the retainer. It changes the rate of lift and produces more flow as the valve rises off the seat. Its DUMB to even think you could use rocker ratios greater than what the engine spec. book calls for. Stop trying to reinvent the wheel.
#23 |
Banned
#24 |
Liked 136 Times in 49 Posts
If the stock stamped rockers were less and all the cam makers know this. What are the odds that just switching to a aftermarket roller rocker will bump the lift at the retainer over the allowed limit?
#25 | |
and while we're at it, is it legal to run less lift than spec? |
#26 |
Banned
Yes.....some do to gain piston to valve clearence and use more duration. Duration and overlap is more important than valve lift. Maybe not so much with the bogus aftermarket pistons of today which give you more piston to valve clearence than the OEM unit.
#27 |
[QUOTE=X-TECH MAN;305163 Remember the Crane stamped steel rocker that came in 1.6 for the small block chevys. Several big name stocker racers were DQ'ed many years ago by NHRA for using these even though the lift checked correct at the retainer.[/QUOTE]
How does NHRA check rocker ratio at teardown? |
#28 |
Liked 2 Times in 2 Posts
I don't know how NHRA does it but I would think the easiest and most accurate way would be cam lift divided by valve lift.
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#29 |
That's right! Anyone making the switch to roller rockers will need a new cam ground. Sounds like the cam manufacturers were all for allowing aftermarker roller rockers.
#30 | |
Liked 1,880 Times in 422 Posts
It's called "area under the curve". Making the rocker move the valve faster than the lobe can with the stock rocker ratio gives you more area under the lift curve.
Alan Roehrich 212A G/S |
