Old 01-22-2012, 09:59 PM   #41
Pvt Parts
Pvt Parts's Avatar
Default Re: Rocker Clarification is up!!!
LOL......More times than I can count. When I went to metal parts inspection a LOT of parts for air craft ejection seats and stuff that goes "BOOM" came in from vendors out of spec.
I have a friend who worked in a job shop that made the pivot pins for aircraft wings during the Vietnam War. I can't post here what went on in that shop.
Old 01-23-2012, 11:06 AM   #42
Jeremy
We need to be carfull of what we ask for.
I am trying to get ready for next year and I've checked several rocker ratios.
Com Cams 1.5's came out between 1.526 and 1.572 all over 1.5.
Pro Comp's 1.6 came out 1.506, some over and some under the 1.5.
Crane 1.5,s came out 1.427, all under the 1.5.
There was considerable differances from rocker to rocker on all of them.
What they say there ratio's are may not be what they really are.
Jerry Stk.4168
Jeremy is offline   Reply With Quote
Old 01-23-2012, 12:28 PM   #43
Jason
Liked 6 Times in 4 Posts
Maybe the old stamped rocker arms aren't so bad after all.
Jason is offline   Reply With Quote
Old 01-23-2012, 12:41 PM   #44
Liked 1,873 Times in 422 Posts
Jerry Stk.4168
Just wondering, what was your test procedure?
Old 01-24-2012, 01:00 AM   #45
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation Re: Rocker Clarification is up!!!
SECTION 10A: STOCK CARS, ENGINE:1, ROCKERS ARMS (Page 5) (1/19/2012)
"OEM or a Aftermarket rocker arm permitted. Either adjustable push rods or adjustable OEM rocker arms permitted on any application, but not both. Needle/roller bearing pivots and roller tips are permitted for all applications. Must remain same design as original application (i.e. stud mount must retain stud mount, pedestal type must retain pedestal type and shaft type must retain shaft type. Stud girdles prohibited.) Stamped steel OEM and OEM-type rocker arms may be reinforced."
Old 01-24-2012, 09:49 AM   #46
ss wannabee
Liked 7 Times in 7 Posts
All good points by everybody here...With all the trouble...almost makes you want to yearn for the old days...the real STOCK Eliminator...(lift-duration-overlap-spring pressure...and REAL stock rockers!)
ss wannabee is offline   Reply With Quote
Old 01-24-2012, 10:22 AM   #47
Jeff Teuton
Liked 325 Times in 50 Posts
Smile Re: Rocker Clarification is up!!!
How about this. Make sure your rockers are the same configuration like the book says. Make sure the ratio stamped on the rocker is the same as the 'blueprint specs', and make sure your cam passes with a solid or blocked lifter. What am I missing here.
Jeff Teuton 4022 STK
Old 01-24-2012, 12:45 PM   #48
Jim Wahl
Jim Wahl's Avatar
Thumbs up Re: Rocker Clarification is up!!!
You all know Jeff is right. If you want to take advantage of the new rocker rule you will have to do your homework! Jim
Old 01-24-2012, 12:59 PM   #49
Jason
Forget the ratio stamped on the rockers. Those numbers evidently mean nothing. Be sure to measure the lift at the retainer AND at the lifter so you can do the math when you check the ratio of the rocker arms yourself. What should be a simple bolt-on is turning out to be a real cluster that no one ever expected.
Remember...watch what you wish for, it might just come true!!!!!
Old 01-24-2012, 01:44 PM   #50
Jeff Lee
Jeff Lee's Avatar
I think it's a real cluster for those that still ask to go to the bathroom...
Jeff Lee 7494 D/S '70 AMX
