Old 01-24-2012, 03:42 PM   #51
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Default Re: Rocker Clarification is up!!!
We can't control manufacturer's tolerances. I mean REALLY... 1.7 ratio... give or take .05.. ?
Who gives a $%#T ? !
Lift at the retainer below blueprint spec... studs, pushrods, springs, all of the specified configuration and mounting. We haven't changed valves, hacked up the heads, or gone over factory lift at the valve.
WHAT is the problem ? !
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 01-24-2012, 03:54 PM   #52
Liked 1,907 Times in 427 Posts
Rocker arms, and valvetrain geometry in general, remain as two of the most misunderstood areas of a race engine. About half of what people think they know about the subjects is wrong. Maybe more.
That's not directed at you, personally, Aubrey, but rather a general statement.
Old 01-24-2012, 04:34 PM   #53
Aubrey N Bruneau
Yeah ? YEAH ? !
HEE HEE !
maybe I know less than that ?
I'm just sayin... It seems to me that much of the reason NHRA removed the spring pressure and duration rules, was to simplify inspection and enforcement. Of course it changed things. This rocker allowance can be simplified too. Merely have a ratio tolerance... IE; +/- .05, and if lift at valve checks ok... we're good.
I understand that "ingenious" folks may discover advantages one way or another. Positioning of the fulcrum-point for one. Shaft rocker setups are probably more stable, but stud rockers are more user friendly.
I dunno
maybe I'm just simple ?!
Old 01-24-2012, 05:29 PM   #54
There already is a rocker ratio tolerance, it is +0.0/-x.x, as they don't seem to penalize anyone for not having enough ratio. You can have the stock blueprint ratio, or less, but not any more than stock. That's tolerance enough, a + 0.0/-x.x is an industry accepted tolerance range.
NHRA checks lift at the retainer, then divides by lift at the cam to get rocker ratio. I'm allowed 0.520" at the retainer, I run 0.518", with 0.306" lobe lift on the cam, for a 1.69:1 rocker ratio.
In Stock, we have to use pushrod length to correct lift, in most cases. That does not change, it's just that with aftermarket roller rockers, you'll need to start from scratch, and get the pushrod that gives you the correct lift, without exceeding the allowed rocker ratio.
Old 01-24-2012, 06:03 PM   #55
mopar jeff
mopar jeff's Avatar
Originally Posted by Jim Wahl View Post
SECTION 10A: STOCK CARS, ENGINE:1, ROCKERS ARMS (Page 5) (1/19/2012)
"OEM or a Aftermarket rocker arm permitted. Either adjustable push rods or adjustable OEM rocker arms permitted on any application, but not both. Needle/roller bearing pivots and roller tips are permitted for all applications. Must remain same design as original application (i.e. stud mount must retain stud mount, pedestal type must retain pedestal type and shaft type must retain shaft type. Stud girdles prohibited.) Stamped steel OEM and OEM-type rocker arms may be reinforced."
How come when I look at NHRA's amendment page this part is crossed out?
Either adjustable pushrods or adjustable OEM rocker arms permitted on any application, but not both.
Does that mean that part of the rule no longer applies?
Jeff Interlicchia
7077 D/SA 1998 Pontiac Firebird LT1
J707 E/T 1966 Dodge Coronet 500
mopar jeff is offline   Reply With Quote
Old 01-24-2012, 06:40 PM   #56
Jeff Teuton
Liked 325 Times in 50 Posts
They threw me out last year for having 1.65 rockers and the spec said 1.60. The cam passed. Up to yall. I got 1.60's on the car now.
Jeff Teuton 4022 STK
Old 01-24-2012, 08:01 PM   #57
Jeremy
Jeff, I thought that was just to keep you from getting horsepower!
Jerry
Did they really check or just see what was on the rocker?
Jeremy is offline   Reply With Quote
Old 01-24-2012, 11:08 PM   #58
Jeff Teuton
They read the rocker stamp. And when I went to Indy, they read it again.
Old 01-25-2012, 03:47 AM   #59
Bill Edgeworth
Jeff;
In my opinion it was very unjust that you got tossed for what was written on the rocker arm. As Allan mentioned valve train geometry is a very misunderstood thing and just because they say 1.65 on them does not mean they are that ratio on your engine. In many (most) cases when you are running longer than stock length valves you can never achieve the advertised ratio of the rocker unless you run an extremely long pushrod and totally mess up your geometry.
For those that are not familiar with the circumstances that cause this let me explain; many engines like Jeff’s Mopar engines or my Pontiac stuff have converging angles between the valves and rocker studs or pedestals in the case of the Mopar engines. So when you run a longer valve than stock the distance from the pivot point of the rocker to valve tip decreases effectively reducing the rocker ratio. So with longer valves those rockers with 1.65 written on them may not even be 1.6.
I believe the reason the factory designed them this way is to reduce side loading on the studs at maximum lift (maximum valve spring pressure)
So this is just a couple of the issues you have to consider when figuring out your spring/valve/retainer combination.
I’m betting when they tossed Jeff they did not check his rocker ratio they based their decision on what was written on the rocker arm???
Aubrey; If you look at what I have said there is more of an issue with how we use the arms compared to conditions under which their ratio was calculated than a tolerance issue.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 01-25-2012, 09:31 AM   #60
Liked 10,850 Times in 2,254 Posts
Bill I think you can use longer than stock valves in super stock, but not in stock.
