Old 02-25-2012, 08:42 PM   #1
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Question Index auto trans bell-housing
INDEX AUTO TRANS BELL-HOUSING
So the center line of the crank and the T/Q align perfectly.
Anyone here ever try to do it or can it be done??
Would it be worth it?
MEXJOE is offline   Reply With Quote
Old 02-25-2012, 09:09 PM   #2
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: Index auto trans bell-housing
Yeah, Been there, done that but, didn't see a thing. I was really trying to fix a trans leak I thought was related to not being centered. Turned out to be a hair line crack in converter.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 02-25-2012, 09:43 PM   #3
Jim B
Did do it as a matter of procedure but unless the trans case was involved in a catastrophe explosion I never found one that was out of centerline by more than .009" and that was usually at the back of a line bored block. In a vehicle that keeps cracking converter necks I might suspect that as a cause but I usually found the actual welding process or a ballooned converter was the culprit for that. (Besides, that's why they call it a flex plate) It's probably not a horrible procedure to include in the build process but in reality it probably is an extra 15 minutes that isn't show any problem. 10 to15 minutes to eliminate/discover a potential problem? Your call as to include it or not but in my opinion it's one less unknown in the initial build if done.
Jim B is offline   Reply With Quote
Old 02-27-2012, 07:45 AM   #4
Eric Kitzan
Eric Kitzan's Avatar
I know you asked about an auto bellhousing but I was watching something the other day and they centered a manual bellhousing. They said it was worth up to 5hp and 5 footlbs of torque.
Eric Kitzan
66 Chevelle Malibu Wagon
Stocker
Eric Kitzan is offline   Reply With Quote
