Old 02-29-2012, 04:27 PM   #1
racer913
Default control arm bushings for 1st gen camaro
rebuilding front end on my 67 camaro I could just some help deciding who makes good bind free bushings
racer913 is offline   Reply With Quote
Old 02-29-2012, 04:44 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: control arm bushings for 1st gen camaro
Global West, Afco and others. That said, the same can be accomplished by modifying poly graphite bushings by adding a zerk fitting, cutting a grease groove in the bushing and turning down the sleeve which is what I had on my Chevelle.
Old 02-29-2012, 05:35 PM   #3
Chad Rhodes
actually no it can't. The poly bushing will still deflect, albeit less than the stock rubber one. The Del-A-Lum style that global west sells will not and will still move just as free if not more so.
Chad Rhodes 2113 I/SA
Old 02-29-2012, 05:38 PM   #4
1320racer
1320racer's Avatar
worked well for me, footbraking my 3880 lb, Chevelle to a 1.28 best 60 foot with 59% of that weight on the nose.)
Old 02-29-2012, 05:40 PM   #5
Chad Rhodes
whoopdie f'n doo. I was just pointing out that no, "the same can't be accomplished" by modifying a poly busing. Deflection may not matter to you, but to a lot of class racers it does. Since you aren't one, you don't get it.
Old 02-29-2012, 05:52 PM   #6
1320racer
1320racer's Avatar
oh I forgot, only class racers get it.
FYI, one of the best stock/super stock builders in the country disagrees with you.
Old 02-29-2012, 05:56 PM   #7
Chad Rhodes
then I'm sure he'll be along shortly to point out why
BTW we've all seen the pics of your cars OVER AND OVER....................we don't care anymore
Old 02-29-2012, 05:58 PM   #8
1320racer
1320racer's Avatar
he won't, he's not interested in posting on the net debating with those that think they know.
speak for yourself
Old 02-29-2012, 08:07 PM   #9
mannymen
Liked 13 Times in 7 Posts
Wink Re: control arm bushings for 1st gen camaro
Ed did u just grind off your serrations from the bushing shells? To the other person responding, class racers still use this method that Ed has mentioned.
C.R. no reason to attack someone trying to help. Plus ask Dan fletcher what bushings he was using as u may be surprised.
N/A
mannymen is offline   Reply With Quote
Old 02-29-2012, 08:37 PM   #10
racer913
thanks for the direction i will be looking around the pits in gainsville I was down to the global west or afco both seem pretty much the same not sure if I should pick one over the other
thanks again
