rebuilding front end on my 67 camaro I could just some help deciding who makes good bind free bushings
Liked 759 Times in 379 Posts
Global West, Afco and others. That said, the same can be accomplished by modifying poly graphite bushings by adding a zerk fitting, cutting a grease groove in the bushing and turning down the sleeve which is what I had on my Chevelle.
actually no it can't. The poly bushing will still deflect, albeit less than the stock rubber one. The Del-A-Lum style that global west sells will not and will still move just as free if not more so.
Chad Rhodes 2113 I/SA |
worked well for me, footbraking my 3880 lb, Chevelle to a 1.28 best 60 foot with 59% of that weight on the nose.)
![]() ![]() Last edited by 1320racer; 02-29-2012 at 05:46 PM. |
whoopdie f'n doo. I was just pointing out that no, "the same can't be accomplished" by modifying a poly busing. Deflection may not matter to you, but to a lot of class racers it does. Since you aren't one, you don't get it.
oh I forgot, only class racers get it.
![]() ![]() FYI, one of the best stock/super stock builders in the country disagrees with you. ![]() Last edited by 1320racer; 02-29-2012 at 05:55 PM. |
#7 | |
BTW we've all seen the pics of your cars OVER AND OVER....................we don't care anymore
he won't, he's not interested in posting on the net debating with those that think they know.
speak for yourself |
Liked 13 Times in 7 Posts
Ed did u just grind off your serrations from the bushing shells? To the other person responding, class racers still use this method that Ed has mentioned.
C.R. no reason to attack someone trying to help. Plus ask Dan fletcher what bushings he was using as u may be surprised.
N/A Last edited by mannymen; 02-29-2012 at 08:12 PM. |
thanks for the direction i will be looking around the pits in gainsville I was down to the global west or afco both seem pretty much the same not sure if I should pick one over the other
thanks again |
