Old 03-15-2012, 10:11 PM   #11
b.guggenmos
b.guggenmos's Avatar
Liked 3 Times in 1 Post
Default Re: ANOTHER 2-Step wiring-in question !
Originally Posted by SStock1373 View Post
Aubrey I have the same setup in my stocker and super stocker. I use the MSD8960 relay, powered by the linelock button. You stage the car so your foot is hitting the two step button off and on but nothing is working until you tap the line lock button after you stage. Now the two step button on the pedal has been activated and is now holding the linelock and the two step rev limiter at the same time, when you launch the car your foot comes off the button and the whole circuit opens so you can still hit the clutch on the shifts but the two step rev limiter won't activate because it must first be powered by the linelock button. Find the MSD8960 instructions and you will see how to wire it.
Bobby,
When doing your burnout does it not engage the low side of the 2 step or do you have to do anything special at that point? What did you use for a clutch pedal switch? Thanks, Brian
b.guggenmos is offline   Reply With Quote
