Old 04-14-2012, 07:30 PM   #1
philbilly
philbilly's Avatar
Default Two Step?
On the brake pedal? What works best. Brake light switch of some sort or a button mounted to brake pedal. I tried the brake light switch (factory) and it seemed really slow. I give it 15 or 20 hits then swapped to a trans brake button which seemed maybe .030 quicker. I seem to be consistant but I need anothe .020 to be in the game
philbilly is offline   Reply With Quote
Old 04-14-2012, 07:58 PM   #2
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Re: Two Step?
If NHRA Stock, it must be mounted on the brake pedal.
Old 04-14-2012, 10:25 PM   #3
65racer
Maybe something like this will
work for you Phil.
Davehttp://classracer.com/classforum/attachment.php?attachmentid=11275&stc=1&d=13344566 73
65racer is offline   Reply With Quote
Old 04-14-2012, 11:23 PM   #4
Kegracing
I like the brake pressure switch. Tried light switch, but like the brake pressure better. Some use a gauge, others dont.
Put a simple toggle switch inline for on/off, so no issues in water box, etc.
Also, some use a micro switch on the shifter so it only works in low gear. Others use a RPM window switch to do the same thing... dont want it on the top end!
good luck
Ken
Kegracing is offline   Reply With Quote
Old 04-15-2012, 08:26 AM   #5
philbilly
philbilly's Avatar
I have a b&m mushroom mounted to the pedal for today at tristate. I didnt care for the light switch. I will call the folks and check out the pressure switch. I did score a final in the bracket race last week so I feel I am going in the right direction.
I have the micro switch on the shifter so that the two step only works in low gear. I got 28 in fronts gonna take them off and put 24 on today and see how close I get.
Old 04-15-2012, 10:23 PM   #6
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Definitely brake pressure switch. Many guys experience consistency issues with the standard "button on the pedal" deal. Folk will hook you up.
Old 04-16-2012, 07:02 PM   #7
philbilly
philbilly's Avatar
I put the B &M button on and went to rnd 5. My worst was a .018 and unfortunately I was perfect when I lost. I thought that wasnt to bad. Seemed like I had to stay after it tho.
Old 04-16-2012, 07:53 PM   #8
Michael Beard
da's some drivin' son! Good job!
Old 04-16-2012, 11:42 PM   #9
69Cobra
Liked 2 Times in 2 Posts
Good drivin Phil!!! .018 as a worst is pretty good I think. LOL
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 04-18-2012, 02:48 PM   #10
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
You keep on you're gonna get good LOL see ya some where soon.
Mike Taylor 3601
