Old 04-23-2012, 12:20 AM   #1
Lonnie Cox
Default Cometic gasket?
A small block chev gasket 40 thou thick,how much will it compress to?
Lonnie Cox is offline   Reply With Quote
Old 04-23-2012, 01:13 AM   #2
Liked 1,903 Times in 427 Posts
Default Re: Cometic gasket?
A Cometic gasket will only compress to the thickness of the individual pieces. Usually you have a 0.020" stainless piece in the center, and then two coated pieces riveted to it. Measure the unembossed thickness of the two coated pieces, and add that to the 0.020" stainless piece in the center, that's your minimum compressed thickness.
Old 04-23-2012, 07:05 AM   #3
BillK
Liked 30 Times in 17 Posts
Lonnie,
You can call them to verify it, but as far as I know, the thickness listed is the compressed thickness. In other words if the gasket part number ends with -40, it will be .040 compressed thickness.
Bill Koustenis
BillK is offline   Reply With Quote
Old 04-23-2012, 09:29 AM   #4
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
I think they give you the compressed thickness and the cc's.
rickseeman is offline   Reply With Quote
