Old 05-13-2012, 07:05 PM   #1
rod
Liked 20 Times in 15 Posts
Default MS 1110H bearings ?
please tell me more about these bearings. are these real bearings or just spacers. $206 seems like a lot for a set of mains. however, to be able to use a 4 bolt block......
is it possible to use a set of stock 350 main bearings [in a 350 block], have them honed and then use the small journal main bearing on them?
thoughts or ideas
thanks rod in AZ
rod is offline   Reply With Quote
Old 05-13-2012, 07:51 PM   #2
JRyan
Liked 112 Times in 31 Posts
Default Re: MS 1110H bearings ?
Rod, the MS1110H bearings are the special double thick one-piece bearing that you can bolt directly into your 4-bolt block with a small journal crank.
Jerry
Old 05-13-2012, 09:03 PM   #3
BillK
Liked 30 Times in 17 Posts
thoughts or ideas
thanks rod in AZ
Rod,
By the time you go through all of that, you will have spent a lot more than just buying the $200 set of bearings, plus I have never liked the idea of bearing spacers or stacking them like you are thinking of doing. I know guys did it for ages on the 400 blocks with a 350 crank, but why take the chance of having two things in each postition that can move around ??
Just my opinion,
Bill Koustenis
BillK is offline   Reply With Quote
Old 05-14-2012, 08:46 AM   #4
NWDragracing
Shop around, especially in Ebay.
http://compare.ebay.com/like/120872007691?var=lv<yp=AllFixedPriceItemTypes&var= sbar&_lwgsi=y&cbt=y
NWDragracing is offline   Reply With Quote
Old 05-14-2012, 12:20 PM   #5
bert powell
Liked 34 Times in 12 Posts
Don't want to highjack the thread but do they maqke these for a bbc? Like to use a 409 main journal in a 454 block?
bert powell is offline   Reply With Quote
Old 05-20-2012, 08:39 PM   #6
rod
i looked at the pictures on e-bay. there are 12 pieces there. what are the copper shells for? they look like inserts for the rear main. right or wrong?
thanks for all the replies
rod in AZ
Old 05-20-2012, 10:50 PM   #7
JRyan
Rod,
Yes, the rear main uses a spacer on the MS1110-H.
Jerry
Old 05-20-2012, 11:41 PM   #8
FED 387
Liked 333 Times in 180 Posts
My experience issome of them are fully grooved depending on if you get "newer stock or older stock"---they only come in 3 sizes so if ya cut the crank more than .010 ya cant use em ----and yes the rear main uses a spacer---very expensive about $170-200 depending on who ya get em from----FED387
Old 05-31-2012, 07:40 PM   #9
firebird
I just got my clevite mains---is there any instruction on the rear main spacer--like loctite or? i would like your expertise please--thanks--spacers make me nervous
firebird is offline   Reply With Quote
Old 05-31-2012, 07:50 PM   #10
Liked 1,872 Times in 422 Posts
Never use Loctite on a bearing, it inhibits heat transfer, and slightly alters the fit.
