Liked 5 Times in 5 Posts
my dad is trying to find a set of aftermarket heads(steel or alum) that will work with a dome piston. he has called several places and they tell him their heads will not work with a dome pistons. any info would help thanks hason ssja2021
Liked 25 Times in 16 Posts
What pistons do you have? If you don't have them yet, check Diamond pistons. Their piston is advertized: "Designed to fit most OEM open and closed chamber heads". I think Ross and others will tell you what chambers they are designed to fit.
Mopar 2 Ya! |
james
they are JE pistons is all i know we was running 915s |
Liked 2,487 Times in 698 Posts
I ran the Edel. RPM with Domed pistons and the Stage 6 Mopar for many years before that with domed. I used 2295 TRW Domed for twenty yearsor so (Still do in our Bracket Stuff). I Believe the B1 and Indy may take a
dedicated design dome and special valve pockets. The JE Sportman series should accommodate either of those Entry level Aluminum Heads.......Check with JE (I think they are still in Huntington Beach, Ca.). Last edited by GTX JOHN; 05-25-2012 at 08:27 PM. |
http://www.jepistons.com/Catalogs/Au...edge_dome.aspx
They don't specify which dome(s) fit these pistons. I don't see a dome for the SRP pistons for a 440. http://www.jepistons.com/Catalogs/SR...-440_flat.aspx It looks like you need to call them. I'd figure they would design it for a 906 type head, but that is a guess.
Mopar 2 Ya! |
Liked 2 Times in 2 Posts
Call 440 source and see what they have. Their pricing is good.
