Old 06-04-2012, 12:46 PM   #1
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
Default BBC fab valve covers
Getting ready to get my car out (I hope). I know I'll need taller valve covers because of roller rockers. Like the look of the fabricated one's but, wanted the pro's and con's of them. Noticed on BBC there is two types available. 1 with short screws and 1 with long screws. Price seems to be ALL over the place too. Recommendations?
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 06-04-2012, 01:41 PM   #2
Default Re: BBC fab valve covers
I don't care for the fabricated valve covers. You simply pay a ton of money to look like the Pro Stock guys. Half of them hold oil in the rail and make a mess when you take them off. We have a set on the Super Stock engine, I get the urge to find a trash can for them every time I pull them off.
I'd just as soon have a decent set of die cast aluminum valve covers, they don't warp, and they don't leak. The only draw back, if it is one, is a couple of pounds of weight. If weight is a problem, stamped steel or stamped aluminum, with load spreaders, is the way to go. Just throw the load spreaders away every year or so, because they make them out of cheap steel, and then when they chrome them, they bake the heat treat right out of them, so they end up soft. It'd be great is some one would make some load spreaders out of spring steel or cold rolled steel, and just coat them, cad plate them, or iridite them, so they'd stay real stiff.
Old 06-04-2012, 01:56 PM   #3
Chad Rhodes
Terry, you're going to have to have the driver's side one notched.....ask how I know
Chad Rhodes 2113 I/SA
Old 06-04-2012, 02:55 PM   #4
Terry Cain
Terry Cain's Avatar
Chad,
@#!$ forgot about that. Grrr, ain't been nothing that would fit out of the box on these fiberglass cars.
After doing a little research, No one pays to run thier valve covers except MOPAR. How much trouble you think it would be to modify a set of Mopars to fit a BBC?
Alan,
Good point about oil laying in them. Need to get oil back to bottom ASAP.
Terry Cain ???? STK
Old 06-04-2012, 08:07 PM   #5
Chad Rhodes
Chad,
Alan,
That held oil will also start a fire if a gasket leaks. Once again, ask how I know
Old 06-04-2012, 11:14 PM   #6
Terry Cain
Terry Cain's Avatar
OK Chad,
How do you know?
Terry Cain ???? STK
Old 06-05-2012, 12:28 AM   #7
I seem to remember an episode about that ...............................
I was not around for the fire though ...................................
Old 06-05-2012, 02:59 AM   #8
Jeff Lee
Jeff Lee's Avatar
I believe the original OEM load spreaders were Corvair items. Find some Chevrolet p/n for a Corvair, I'd imagine they are much better parts.
Jeff Lee 7494 D/S '70 AMX
Old 06-05-2012, 07:52 AM   #9
Chad Rhodes
OK Chad,
How do you know?
do NOT use a cork gasket, as the sharp edge on the aluminum will eventually cut them in half, it then becomes like a faucet onto the headers. Even with coated headers, it will start a fire on the return road. Thank God dad was able to put it out before it damaged anything. We use the rubber/steel core gaskets now and there is no problem, of course we probably ran the cork ones way too long
Old 06-05-2012, 09:40 AM   #10
Jeff, that is indeed correct. The problem is that they work well for a small block Chevy, and some other engines, but they don't work well on most big block Chevy valve covers.
