Old 07-04-2012, 08:44 PM   #41
Ed Wright
Ed Wright's Avatar
Default Re: Pure Stock-1995 Olds Achieva
Good luck.
Ed Wright 4156 SS/JA
Old 07-04-2012, 09:18 PM   #42
Robert Swartz
Robert Swartz's Avatar
Originally Posted by Tod Lane View Post
Point taken, but if Autozone will test for free I am thinking eliminate one possibility...
By the way, Robert and I appreciate all the help! This thing is driving us nuts
X2
Yes, Ed, thank you very much.
What I'm happiest with, I finally found something that the car reacted to. It made a change. Which means I can start to isolate something. I went out and pulled the valve cover with the housing, coil packs and controler for the coil packs. I will take it by Advance tomorrow. I think they do electrical testing as well. I've been dealing with them quite a bit here lately.
If the coils and housing check out. We can say something isn't the problem. Then start to look at the things that could be contributing. Would've never dreamed I'd get into this much work for a "slow" car! Just have to chuckle, car seemed to run OK until I started working on it.
Anyway, Tod, we'll still have some work cut out for us Saturday.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 07-05-2012, 09:49 PM   #43
Robert Swartz
Well, Autozone nor Advance Auto could test the coil packs. Only thing they could test was the ignition control. Car starts and runs, not the culprit.
Came back home and in a vain attempt, threw a new set of plugs in it. Started it, ran the same. Pulled both 1 and 4 injector clips, car still ran the same. Pulled the new plugs out, 1 and 4 never fired, 2 and 3 had a tannish color.
May pick up a housing and coil packs after work tomorrow.
Name:	olds plugs (1).jpg
Old 07-06-2012, 06:04 AM   #44
Ronnie Hamlin
Liked 29 Times in 8 Posts
I'm not familiar withthe design of this engine but since it has coils packs, can you swap the ones that are firing with the ones that are not to see if the problem is failed coil packs?
It seems unlikely that two would fail at the same time. I'm not real big on throwing parts at a problem to try and fix it. A DVOM and a lab scope will show you a lot when working on electrical issues.
Ronnie Hamlin is offline   Reply With Quote
Old 07-06-2012, 06:15 AM   #45
owen
check the housing the coil packs are in. big white ugly thing. it could be the problem.
owen is offline   Reply With Quote
Old 07-06-2012, 05:44 PM   #46
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Just FYI, each coil pack fires two cyl on this motor. 1 and 4 are paired as is 2 and three.
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
Old 07-06-2012, 05:59 PM   #47
art leong
Is that a wasted spark motor? Also are the injectors batch fired or sequential?
Art Leong 2095 SS
Old 07-06-2012, 07:57 PM   #48
Robert Swartz
Art,
Yes it's a wasted spark motor. The coils fire the injectors in pairs, one coil fires #s 1 and 4, the other coil fires 2 and 3. When I pulled the injectors individually, the engine ran the same. With 1 and 4 being the non-firing injectors. When I pulled 1 and 4 at the same time, the engine ran the same. I had new plugs in it at that time. stopped the engine, pulled the plugs, 2 and 3 had a tannish deposit, 1 and 4 were clean, they had not fired.
This isn't a fresh engine. IF we keep the car. I can pass this off as a learning experience. Right now, I just want to hear it run on 4 cylinders again.
Old 07-06-2012, 08:11 PM   #49
Robert Swartz
Ronnie,
Thanks for the advice. I need to get a stethoscope. Yes, this has taught me, you can't have enough test equipment. I'll need to upgrade my ability to diagnose electrical functions, if we keep this car.
Throwing parts at one of these "newer" cars can get expensive real fast. I don't think there's anything on this car that cost less than $35, LOL! At the current rate, I'm going, I will have almost half what my boy gave for the car. We really haven't done anything to it.
I went ahead and purchased both packs and a new housing. If I just change one, my luck the other pack will go down in a short time.
