Old 07-21-2012, 10:56 AM   #1
stefan callender
stefan callender's Avatar
Liked 2 Times in 2 Posts
Default Efi
What EFI system does everyone run??
Old 07-21-2012, 12:59 PM   #2
TOSTO RACING
TOSTO RACING's Avatar
Liked 652 Times in 184 Posts
Default Re: Efi
Stock pcm for me. I'm probably the only one with this setup. Fast and Bigstuff are very popular.Depending on what you are doing, there is really no advantage to the aftermarket ones. They are just easier to work with and tune.
Tim
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 07-21-2012, 04:11 PM   #3
Ed Wright
Ed Wright's Avatar
Default Re: Efi
The factory boxes are just as easy as the after market stuff.
Ed Wright 4156 SS/JA
Old 07-21-2012, 04:32 PM   #4
NewHemi
NewHemi's Avatar
Default Re: Efi
I can't imanine that you can get the same kind of fuel and spark control and logging and data out on a stock ecu that you can get our of something llike the FAST system.
But if $ is an issue, run stock until you decide you need more control or more data out.
Then when you need more than your stock setup gives you, look around at what the faster cars in your class are running, and go for that.
My Opinion. I never ran a stock ECU in Class, Your mileage may vary.
David
The New Hemi Guy
NewHemi is offline   Reply With Quote
Old 07-21-2012, 05:04 PM   #5
Ed Wright
Ed Wright's Avatar
Default Re: Efi
Oh, but you can.
Old 07-24-2012, 12:42 PM   #6
Marty Buth
Liked 232 Times in 39 Posts
Default Re: Efi
I use the SDS (Simple Digital Systems) for my EFI. It really is simple. It is on the NHRA approved list. It is used also for light aircraft due to it's reliability. I know of a guy that tried to use the stock ECU and had major issues with head gaskets popping. You can do it with a stock ECU, but I think it is much easier to tune with the aftermarket ECU's.
Marty Buth 3657 STK
Marty Buth is offline   Reply With Quote
Old 07-24-2012, 12:55 PM   #7
Ron Middleton
Liked 12 Times in 4 Posts
Default Re: Efi
I think it all boils down to how up to date your ECM/Program is and how talented you are at tuning. Most of the major players such as Big Stuff, Fast, Holley, etc. are close to plug and play with minimal tuning by the end user. On GM's EFI Live and HP Tuners can tune the stock ECM as well but require much more knowledge and tuning experience. Systems like Megasquirt and others are also quite capable but require much more tuning knowledge and setup than FAST, Big Stuff, etc. Just make sure and purchase the newest version you can get, just like computers aftermarket ECM's get outdated pretty quick
(still useable but the newer stuff is almost always better). JMT.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.”
- Aristotle
Ron Middleton is offline   Reply With Quote
Old 07-24-2012, 12:56 PM   #8
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Default Re: Efi
Marty:
Do you use the SDS EM-4 on your Turbo Coupe ?
I see it's plugs into the factory harness.
Or did you go with a custom setup ?
http://www.wmsracing.com/new_wms/wms_efi.php
BTW:
How good is the tech support at SDS ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 07-24-2012, 02:23 PM   #9
Ed Wright
Ed Wright's Avatar
Default Re: Efi
No reason at all the factory ECU would hurt head gaskets (or anything else) if the tuner knew what he was doing. The aftermarket boxes still need tuned. Most offer a selection of start-up tunes for starting places. Seldom real close to a race tune up.
Old 07-24-2012, 05:05 PM   #10
art leong
Default Re: Efi
I use Vi-Pec. It's got a built in datalogger (up to 10 runs). All the bells and whistles of the top brands. At half the price. Plus you don't need to buy all the special sensors, for the most part you can use what you have.
Art Leong 2095 SS
