Old 01-07-2013, 10:56 AM   #1
Rob Lloyd
Default Low-HP Short Time?
For those of you running a 'Low' HP stocker (I thinking like ~250hp), what kind of short times are you getting? I am now at about 1.7 in the 60' with my new M&H tires, but my car is FWD. So, I'm interested to know how it compares to a RWD 'low' HP stocker. I know the higher HP cars are in the 1.4-1.5 range. But, It's probably not accurate to compare my car to that.
Rob Lloyd 3728 BF/S
Rob Lloyd is offline   Reply With Quote
Old 01-07-2013, 12:46 PM   #2
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Default Re: Low-HP Short Time?
Rob, my current car (DF/S '92 Olds Toronado, 231 cid. 170/170hp) goes 1.90's in 60' (actually quicker than my old daily driven '95 Camaro LT-1 which had a 1.98 short time on a 13.88 @ 97 mph run). Olds was 1.95 on a 15.01, 89 mph pass at 3,500 pounds. I think the old BF/S turbo Sunbird (110 cid, 150/150 hp) I drove for Billy Nees went low 1.90's running 14.1's in the 1/4 at 2,600 pounds.
Old 01-07-2013, 06:48 PM   #3
GTX JOHN
Liked 2,487 Times in 698 Posts
My boy has a Aspen wagon that run N/O/P. It generally run Mid 1.5s
at O Weight (3650). It has run a Best of 1.498 at N Weight (3540) at
Pomona last year.
Small Valve Low Po 318 @ 230 HP.
ProTrans made a ton of difference with straight cut Very LOW Gear!
NOT inexpensive but it made a huge difference in performance and
worth every penny!!
Old 01-07-2013, 06:57 PM   #4
art leong
Rob my car using the trans brake went mostly low 1.7's in decent air. Using the footbrake I slowed to low to mid 1.8's in good air.
When I put the 22" tires on low 1.9's are about as good as I've gone. Haven't tried them in real good air.
With my car air makes a world of difference in the short times.
The turbo might make up some air difference though.
If I remember correctly I was 1.7's most of the time with the Turbo car.
Art Leong 2095 SS
Old 01-07-2013, 07:16 PM   #5
CJ McDonald 9564
Liked 11 Times in 6 Posts
My E/PS 83 Camaro has 1.67's at 3240 lbs. I just got it this past fall and have not had much time to experiment, but I don't think there's much left in it.
C J McDonald
CJ McDonald 9564 is offline   Reply With Quote
Old 01-07-2013, 09:55 PM   #6
Chris Hill
Liked 244 Times in 26 Posts
Best 1.69 running 13.29 in r/sa. 3500 lbs c-10 pickup with 4.3 v6.
Chris Hill
Old 01-08-2013, 10:50 AM   #7
Rob Lloyd
Ok, thanks guys. So far it seems like my mid 1.7's are pretty good for a FWD ~180hp car.
I had a few ideas to try and improve that (IE, better struts/shocks, but they're spendy). But, it seems like I probably won't see much improvement there.
Rob Lloyd 3728 BF/S
Old 01-08-2013, 11:39 AM   #8
art leong
Two words. Boost Control . The Mitsubishi spools up quick enough to spin the tires
The M&H's work better but still about 30' out in good air I would spin. If I could have had better boost control I could have gone quicker.
I could hook at the line so I don't think suspension (other than super long wheelie bars) will work.
Art Leong 2095 SS
Old 01-08-2013, 02:26 PM   #9
Rob Lloyd
Boost control is OK right now. I usually get a little rotation off the line, but not too bad.
I was also considering wheeling bars - or more correctly, for a FWD car, wheelbase extenders.
Rob Lloyd 3728 BF/S
