Old 02-14-2013, 08:04 PM   #11
Default Re: New for 2014
Originally Posted by Dinsdale View Post
SECTON 20: GENERAL REGULATIONS, ENGINE: 1, 1.3 EXHAUST (Page 3)
(2/4/2013)
Exhaust collectors/stacks must be securely fastened (i.e., metal connector
straps, bolted, welded, etc.) to prevent loss of collector/stacks during competition.
Effective Jan. 1, 2014, removable multi-piece exhaust collectors/stacks must be
securely fastened with an NHRA accepted header tether, such as Lokar’s
1400009 or 1401009 to prevent loss of collector/stacks during competition.
So even if the collector is strapped, bolted or welded to prevent loss a teather is still required. Certainly makes a lot of sense to me.....NOT!
Dale , I don't think "welded " would be considered "removable"...
Maybe it does ..with these guys..You never know.
http://www.lokar.com/product-pgs/dra...g.html?t=34740
Nice! Classy!
Old 02-14-2013, 08:40 PM   #12
65signet
Liked 49 Times in 22 Posts
Originally Posted by KRatcliff View Post
Wait until you hear how my LSxxx sounds with the Tri Y's from my header hippie.
That is funny
65signet is offline   Reply With Quote
Old 02-14-2013, 09:17 PM   #13
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
What a joke! It BOLTS on. So their "Approved" bolts are more secure than your bolts.
Larry Merk
Larry Merk is offline   Reply With Quote
Old 02-14-2013, 09:45 PM   #14
No kidding. Typical overreaction .
How about "Two welded tabs or straps on each collector, 1/4 -20 bolts, lock washers required"
Then have a tech get down on the ground and look under the backside with a mirror.
I know. "fat" chance of that happening...(Not you, Travis)
Old 02-14-2013, 10:13 PM   #15
SSDiv6
I agree with Mark; welded tabs with the proper fasteners should be acceptable. If NHRA still has a concern, then use and aviation high temperature lock washer such as the NAS1061, and use a high temperature aviation lock nut such as the MS21046 which is good to 800°F.
Old 02-14-2013, 10:22 PM   #16
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: New for 2014
So this "tether" will keep any loose exhaust tubing "contained" under your car, potentially bouncing around and beating on your fuel/trans lines, oil/trans pan and/or the driveshaft?
I also wonder if this has any affect on cars using full exhaust systems, with or without mufflers.
Old 02-15-2013, 12:06 AM   #17
Frank Bialas
Frank Bialas's Avatar
Liked 23 Times in 13 Posts
What about an exposed brake line, or if you get really lucky and it hits/bangs your shifter linkage say maybe into reverse,Then what???
Frank Bialas 1570 STK
Frank Bialas is online now   Reply With Quote
Old 02-15-2013, 12:23 AM   #18
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Not for nothing but a few years ago a T/S car lost a collector at Atco doing a burnout and launched it into two spectators.I Very horrible scene.I know one of them and he's still feeling the effects.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 02-15-2013, 12:35 AM   #19
treessavoy
Liked 4 Times in 4 Posts
This is just stupid or a payoff to lokar!
JimR
Jim Rountree
Old 02-15-2013, 01:29 AM   #20
Eddie, I hear ya, but have you ever seen tech guys check collectors to see if they are securely fastened? I haven't.
Who got your seat in the Geo?
