Old 06-01-2013, 12:49 PM   #11
fordteacherguy
Liked 160 Times in 51 Posts
Default Re: Sunoco fuel at Norwalk
Brent:
NHRA Stockers/Super Stockers may only use "spec fuels" listed on the NHRA website under accepted products list, page 93.
All fuels on the acceptance list have a specific dielectric value range that is checked periodically throughout qualifying and the race to ensure no illegal additives are added to the fuel.
So short answer is yes, you need to use only fuels listed on the acceptance list. Some check better than others. Some manufactures have occasionally let out some bad batches that won't pass tech. As for Sunoco Purple, I have ran that fuel for 5 years with it almost always checking "Low". Talking to the national event fuel checking guy, he was up front that he see the problem with Sunoco getting low more out on the west coast than back east, so maybe there is a deterioration problem with storage, transfer and travel. My divisional tech guy also passed on that he thought Sunoco was shipped in bulk, and then pumped into barrels, allowing the possibility of more inconsistency in the fuel the farther it traveled. Seemed plausible. He mentioned that VP was canned on site and shipped from the factory which was why it probably checks more consistently.
All in all, have whatever fuel you use checked when you are at the track before you run. If you are low , you might be able to find a fresh source of better fuel from another racer to bring it up. Just ask the fuel checking guy who else is running the same fuel as you . He will have the car #s to find your secondary source. Good Luck out there!
fordteacherguy is offline   Reply With Quote
Old 06-02-2013, 10:22 AM   #12
BBF67
Liked 8 Times in 4 Posts
Stuck with a drum of Sunoco purple that will not pass? VP C14+ is clear and the right mixture will fix it.
BBF67 is offline   Reply With Quote
