Old 05-30-2013, 02:15 PM   #1
Tar Heel
Guest
Posts: n/a
Default race oil and how much?
I'm changing fluids on our B/PS '04 Corvette and would like to try some race oil. The engine, other than the cam and springs, is completely stock (55,000 miles). What would be a good race oil for the LS1 and how many quarts should I run? The stock capacity is 6 quarts and I've always used Mobil 1 per factory recommendations when we drove it on the street. Now that we trailer it and only race is there ET to be gained? Thanks for any advice.
Old 05-30-2013, 02:22 PM   #2
Chad Rhodes
Default Re: race oil and how much?
I'd keep using Mobil 1, considering the stock bottom end
Chad Rhodes 2113 I/SA
Old 05-31-2013, 05:55 PM   #3
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
i would try 5w20 mobil 1 synthetic 5 qts vs 6 to see if it makes a difference. There isn't much to be gained due to the crankshaft and oil pan design.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 06-01-2013, 01:55 PM   #4
Tar Heel
Guest
Posts: n/a
Thanks, I can do that. Every little bit helps. I appreciate the advice!
Old 06-05-2013, 10:25 AM   #5
Todd Hoven
Guest
Posts: n/a
Just have to make sure you don't clog the cat converter with an oil that has too many off road additives
Old 06-05-2013, 12:15 PM   #6
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Steve:
We are lucky with our engines. Any full synthetic works great..!
Two reasons:
Roller Lifters and Stock spring Pressure.
Which means a lot for reliability.
There maybe a hundredth or 2 between brands.
There is more ET in the car with your wife driving
Dan
Old 06-05-2013, 09:02 PM   #7
Tar Heel
Guest
Posts: n/a
Dan
Amen brother! No worries ... that's the next move. Wonder if she'll be offended if I get her a helmet for our anniversary? She knows that the 130+ lbs. lighter that she is will be worth more than a tenth!!!
