Old 06-04-2013, 08:48 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default Chevy ss block?
I have a chance to aquire a little m dart block @ a very reasonable price (nhra accepted piece) weighing 204lbs. bare its probably heavier than a bowtie unit...is the extra weight being up front going to hurt performance? (SS/GT application/327/3spd/q-jet) any input is appreciated. thankyou!
Old 06-06-2013, 06:41 AM   #2
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Default Re: Chevy ss block?
So you have a line on a little M block at a good price eh....
Well, that block would slow your car down at least 6 tenths, and you wouldnt be able to qualify anywhere in the country.... Therefore, I think you need to give me the contact information for the block, so that I can purchase it at once, just to save any other racer the grief of having it ruin their combo
Seriously, I wouldnt think the extra 20 lbs would even be noticed, and from what I have heard about the M stiffness, it may make more HP and be quicker overall...
Old 06-06-2013, 11:51 AM   #3
richie 2
good one kevin...you had me nibbling! any engine builders know for sure if a dart will make more power over a bowtie, all components (except the block) being equal?
Old 06-06-2013, 01:36 PM   #4
carl hinkson
Liked 18 Times in 10 Posts
I have used both and I can't see where there would be any difference in power between the 2 blocks.
carl hinkson is offline   Reply With Quote
Old 06-06-2013, 02:07 PM   #5
richie 2
then its back too the weight deal...the weight off the front end I'll be better off. i know im splittin' hairs here but I want to invest in the quicker product.
Old 06-06-2013, 03:12 PM   #6
Jeff Lee
Jeff Lee's Avatar
Personally, I'd call Dart and ask them what the "big deal" is. I have to imagine that extra 20#'s is there for a reason.
Jeff Lee 7494 D/S '70 AMX
Old 06-06-2013, 03:30 PM   #7
carl hinkson
What is the P/N of the Bowtie If your comparing bore size to bore size the blocks should be pretty close in weight. What is the PN of the Bowtie in question? As some of the older bowtie blocks were offered in a small bore non Siamese cylinders.
Old 06-07-2013, 12:11 AM   #8
Adger Smith
Liked 880 Times in 311 Posts
Your question should be: How will the 20 lbs on the front of the car help me?
With the suspension set up properly the extra 20 lbs on the front my help your car E.T. It may help you keep it off the wheeliebar crutch.
Adger Smith (Former SS)
Old 06-07-2013, 06:37 AM   #9
richie 2
carl i'll get the numbers...im also going to weigh everything again. I believe the difference between the two is #50. if its #20 im not going to fuss over that amount...I hear ya Auger as ive seen people place another touch on the front for that reason.
Old 06-07-2013, 10:52 AM   #10
richie 2
the dart is 205lbs. the bowtie part #24502503 with a casting #10051184 comes in @ 186lbs.
