Old 07-10-2013, 05:35 PM   #31
Richard Grant
Richard Grant's Avatar
Liked 13 Times in 7 Posts
Default Re: Submit 2014 Rule Change Requests
Jeff, please explain. What is the dynamic eliminator? The requirement of a .350 or faster run before including it in the average?
Richard Grant 4988 STK
Richard Grant is offline   Reply With Quote
Old 07-10-2013, 06:07 PM   #32
Ed Wright
Ed Wright's Avatar
You know Jeff and his big words.
Ed Wright 4156 SS/JA
Old 07-10-2013, 07:39 PM   #33
67chevygary
my suggestion sent to Bruce; Bruce; I'm sure you will be getting a lot of requests for refactoring some of the older cars to make them more competitive with the newer ones but nhra really needs to look into refactoring the most famous racecar of all. those 1955-57 chevs. if nhra could refactor these cars fan interest would increase-young people would get an honest look into the history of the sport and maybe some of us owners would come back to the nhra with our cars instead of bracket racing them!
67chevygary is offline   Reply With Quote
Old 07-11-2013, 12:36 PM   #34
Jeff Teuton
Liked 325 Times in 50 Posts
Two things. The dymanic eliminators are stock and super stock; always changing because the cars, smart tuners, new parts, etc keep them changing all the time. I think that is a given. The static numbers 1.20 under, 1.00 trigger, .350 under (as mentioned) and all the stationary stuff just doesn't work with changing numbers. A system tied to eliminator averages and engine averages with instant looks when a trigger is hit, then the system applies. You know 1.00 under at Gainesville early in the year, and 1.00 at Indy are not the same. An average would move with the time of year. Have as many adjustment periods as you like; 2,3,4. The same data is collected anyway. It would work better, and just reverse the system to take hp off at a faster rate than is currently available, which takes entirely too long and is too limited. Second thing, since I got a new car, I have petitioned NHRA to reduce the hp on the old cars accross the board. My starting point was older than 2008 5% accross the board (its just an excel program) and maybe only 2% for the LS1. Spoke to tech this weekend and in a frank conversation, 5% might not be enough. So it's all out there. I didn't just dream this stuff up. It's been out there. The current system took the politics out of the program, refine it without politics again and it would be much better. I think that is 3 cents worth. I ain't through. Now there are some glitches that happen, like one or two in the nation; I have a provision for that. Over the many years since myself and Wesley studied this (1999), it has provided for everything and is more gentle and user friendly than the current AHFS. When the current system was proposed by NHRA, I accepted it because it was better than what was out there and it at least functions, but not as well as an average system could. I think I would do away with the body family thing. I don't think the data will support this; an engine on a dyno don't know which car it is going in. Maybe a few rare exceptions, but not many. Anyway, I am now up to 5 cents and that all I got for now, but I got a lot more. Maybe some more. I also proposed for NHRA to sublet the data responsibility to Nitro Joe and friends. A small fee to offset the cost, maybe an additional buck per entry, and some sort of fee to the world famous Nitro and company for current information (which is always current) for details. And I got to go somewhere, and we up to a dime now.
Jeff Teuton 4022 STK
Old 07-11-2013, 02:12 PM   #35
Richard Grant
Very Interesting, Jeff. It's obivious that you have put much thought into this concept. It's probably not perfect( nothing is) but at least it begins the process to improve.
Old 07-11-2013, 03:42 PM   #36
Jeff Lee
Jeff Lee's Avatar
From September 2012 discussion on ClassRacer with Andrew Hill's response (to which I agree with):
Originally Posted by Jeff Lee
Want more participation at NHRA events with the "older / traditional" Stock Eliminator cars?
Want to see a qualifying sheet that is not top heavy with late model factory drag cars that leave you with no desire to participate?
Don't want the expense of having a new "crate Engine" class and making your old 350 / 255 Chevy obsolete and having to buy a 383 Vortec engine trying to keep up with the new factory Super Cars?
Do you want to give the new cars a run for their money?
Drum roll.......reduce the HP of ALL 1992 and OLDER vehicles in the class guide BY FIVE PERCENT! No index changes, just an across the board 5%
reduction in HP. For EVERYBODY. This is not complicated. Take 5% off.
Why 1992? Because the LT1 started in 1993. They had their gift already.
I don't care if your combo just had 20 HP taken off last month for whatever reason. Bam! Take another 5% off the weight. Index stays the same.
I don't care that you built your car with the heaviest parts you could find and you can't make the new minimum. You have 3 classes you can run in. Pick one.
AHFS trigger? I don't know. I'm thinking it should remain the same. But I'd sure like the trigger to be based on the 1/8th mile ET.
Thank you. Let the arrows fly.
Andrew Hill response:
Well that makes sense, just get even more people playing the AHFS game! It would make 1000x more sense to add 5% to all post 1992 combinations, it accomplishes the same thing, but doesn't create a bunch of 1.30 under cars from 1.10 under cars.
3207 D/SA
Jeff Lee 7494 D/S '70 AMX
Old 07-11-2013, 03:44 PM   #37
Ed Wright
Ed Wright's Avatar
Jeff, since it would effect fewer cars possibly having to change classes or weights, would it not be simpler to add 5% to all the newer cars? It's pretty obvious they are the problem, not everybody else. Right?
Old 07-11-2013, 04:04 PM   #38
denbreeden
denbreeden's Avatar
Liked 67 Times in 27 Posts
Easy Ed, 5% is way too much for the new cars. I could see maybe 4.5 or 4.75 but 5%? Your killin' me!
Dennis Breeden
denbreeden is offline   Reply With Quote
Old 07-11-2013, 04:04 PM   #39
Jeff Lee
Jeff Lee's Avatar
Ed, you didn't read the entire post.
I posted my thoughts and Andrew Hill said the same thing you are saying. As you can see, I agreed with Andrew (and you).
Old 07-11-2013, 04:07 PM   #40
Jeff Lee
Jeff Lee's Avatar
Combine sticks and autos. I am submitting this to NHRA. I know with 110% certainty it will be shot down of course....
(from an old post but I'm confident the percentages wouldn't be any different today as 1 year ago).
According to Nitro Joe's Stats (from 6/13/12 issue)
Stock / Stick racers: 115
Stock / Auto racers: 836
(RWD classes counted)
Only 13.76% of NHRA racers are Stock / Stick RWD
Super Stock / Stick racers in SS/A through SS/O: 29
Super Stock / Auto in SS/AA through SS/PA racers: 221
Only 13.12% of NHRA racers are Super Stock / Stick RWD
Super Stock / Stick racers in GT/A through GT/M: 31
Super Stock / Auto racers in GT/AA through GT/MA: 260
Only 11.92% of NHRA racers are Super Stock GT / Stick RWD
RWD classes that differentiate between transmissions counted; i.e., not showing SS/AH or Modified. I also didn't show SS/AAA or SSA/A or the truck classes because I don't even know what transmissions are allowed in these classes.
Also realize these numbers are higher because many racers, both stick & auto bounce up or down a class.
Bottom line, less than 14% of all Stock or Super Stock racers use a manual transmission.
