Old 08-29-2007, 09:19 PM   #11
racer913
Default Re: GT stock
Can you tell me a little more about car heads? cam? was the TH 350 stock gears or low first gear set? converter stall what kind of times were you running your car souds just like what I am going to build is your car a low maintance car?
racer913 is offline   Reply With Quote
Old 08-30-2007, 02:44 AM   #12
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
if you want to run "class" & bracket race use a glide with a ....2.08 low gear set. ( if the motor makes alot of Hp use a 1.98) I think you'll be happy. If your just going to run a few "stock" races a year all you need to do is get it under the index......I think you'll be suprised how good a "stocker" is to bracket race. Dad finished 8th in div.3 last year with a car that would run .2 under in the 1/8th and right @ the index in the 1/4! ( best pass 14.25 on a 14.30 index) (h/ps) good luck!
Old 08-30-2007, 08:26 PM   #13
racer913
thank you there is alot of info on here you guys are a lot of help but there is soo much still to learn
