Old 09-21-2013, 05:41 PM   #11
tafc10
Default Re: Carb Size for Engine
SG192L
Thanks heaps for the info.
Geoff
tafc10 is offline   Reply With Quote
Old 09-22-2013, 01:29 PM   #12
jmarkaudio
That car is light, why it runs well. Fuel pressure needs to be addressed first, with methanol and a belt drive pressure should be lower in the 3-4 lb range at idle and low speeds, and 9 or a little above on the top end. As far as a carb, either a custom Holley body 950 with around a 1.45 venturi, a QF based 1.45 venturi carb, or a Dominator set up for methanol.
jmarkaudio is offline   Reply With Quote
Old 09-22-2013, 05:05 PM   #13
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Carb Size for Engine
Call Mike Laws at BLP. He can set you up the right way the first time! Jim
http://www.blp.com/
Old 09-22-2013, 05:09 PM   #14
tafc10
Thanks for your help guys, have emailed BLP, will wait and take their advice, my daughter wants to be back on track and in the seven's soon.
Thanks again.
Geoff
Old 09-23-2013, 12:21 PM   #15
jmarkaudio
I'll second that for BLP, let me know if you have any issues getting through, I live about 25 minutes away from them.
