Old 01-21-2014, 10:20 PM   #11
Rich67stang
Liked 116 Times in 27 Posts
Default Re: Header Tether Requirement Clarification
This has to be the most ridiculous rule needed. If your header collectors blow off because your tabs are rusted/rotted and you do not maintain your equipment, but adding tethers solves the problem...unbelievable.
Richard Preiser
1613 FGT/I 1510 C/SA 161 F/DA
Rich67stang is offline   Reply With Quote
Old 01-21-2014, 11:00 PM   #12
70AARCuda
Liked 11 Times in 6 Posts
Originally Posted by A56 View Post
If you can get the headers on and off the car with the collector extensions on them, then just weld them on, do (3) 1" beads per extension, im sure that will make NHRA happy. If you dont do anything, they might turn you away. If you cant get the headers on and off the car with the collector extension on, pick you favorite tether vendor and buy a kit.
Mark Lelchook
D/ED F/SA
NHRA says a 1" stitch weld required on each tube, in this case the collector is one-tube and the extension is the other. That is how I am understanding it.
Got that answer from one of the vendor about welding the extension...well..got a few weeks before 1st race.
70AARCuda is offline   Reply With Quote
