Liked 187 Times in 56 Posts
To the wire guys,
how would you route the crank trigger wire, over the top of the engine under the intake to the crank, or on the inner fender to the crank???? Would there be an advantage fender over engine??? Comments would be appreciated. Thanks, Bob Lasko Last edited by Bob Lasko; 02-01-2014 at 08:25 PM. |
I found it easiest along the fender , out of the way , more room through the firewall had to extend the wire about 4 ' to box in the backseat---Trevor
Make sure you keep it away from water pump or alternator wires.
Liked 354 Times in 120 Posts
Was told not to run the wire along side of anything that was hooked to electric motor unless it was shielded. Tom
Tom Meyer 5240 SS Stock ??? |
I would not. Why ask for ignition trouble? It can be one of the hardest things to track down and deal with. The crank trigger wire is extremely sensitive to EMI and other electrical influences. It really needs to be run all by itself and carefully shielded completely.
Alan Roehrich 212A G/S |
Also only ground one end of the shielding. If you ground both ends you will make it a EMI antenna.
Art Leong 2095 SS |
Liked 319 Times in 68 Posts
Bob, run the crank trigger separate from all other wires you'll be much happier for it.
Lee Valentine 1661 STK |
#10 | |
Liked 373 Times in 129 Posts
I also ground the heads to the block. |
