#11 |
Liked 60 Times in 12 Posts
Anyone know, for sure, can you do this w/ gas, or only diesel ? I've heard yes's and no's.
2894 STK |
#12 |
Liked 68 Times in 41 Posts
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
#13 |
Liked 66 Times in 31 Posts
If you try this on a gas truck, you'll probably end up with evap. emission problems unless you use a shut off valve and turn it off when the ECM is monitoring evap.
#14 |
Liked 216 Times in 77 Posts
I have a transfer tank in a Gas truck. I put a electric pump out of a Tbi pickup in mine and ran the line to the top of the tank. Through a fitting that I welded into the tank.. And then down to the filler neck with a fitting welded on there as well. If you keep a couple of gallons in the tranfer tank and don't run it dry. It will still hold enough pressure to keep from kicking a CEL for evap. emmissions. Nice part is I can run down the road and flip a switch to fill it up and not have to stop to transfer fuel.
#15 |
EVAP codes can be fixed.
Ed Wright 4156 SS/JA |
#16 |
Liked 33 Times in 16 Posts
I could not stand to drive that long without stopping.
Rich Taylor I/SA - 321 |
#17 |
Guest
Posts: n/a
Grainger or ?? sells a kit for the filler neck with a valve. Gravity flow no pump needed. Works great for the past 4 years.
Emission lines filling could be an issue at the top of the tank. Has not been on the diesel. |
#18 |
I have been tryin to find the right look. I think the tank is going to have to be hidden for me. the tank inside of a tool box is going to be the ticket..
#19 |
Liked 20 Times in 15 Posts
You need to check the state and Fed motor codes. I believe it is illegal to use these style tanks as a fuel tank. There are securing/bolting issues and placement of the tank. It seems silly to be able to carry the fuel and then another to use it as an additional tank. I believe that the tank/tool box units are for transfer only and no gas. I run a 460 dually and wanted to do the same thing. There were more issues than I cared to resolve. I am thinking of using the 2 factory 14 gallon tanks and placing a Explorer rear tank @30 gallons as a back up.
#20 |
These are really nice combo tank/toolbox, they come with fuel gauges. I have a 90 gallon with a 8 inch deep toolbox in the top all alum. ATP. The top of it is level with the bed rails.
http://www.rdsaluminum.com/index.html |
