Old 08-09-2014, 06:53 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default SS GT S-10 headers
Racers,
I am underway with the buildup. The combination is 327/300/293. This will be a "B" class truck.
Truck and much of the chassis needs in house. Engine parts being gathered.
So, about the headers. If you know someone racing an S-10 I need header feedback.
Thanks,
Larry Woodfin 471W
Old 08-10-2014, 01:17 AM   #2
SSDiv6
Default Re: SS GT S-10 headers
Check with FJ Smith.
http://www.smithperformance.com/catalogue_s10_sub.html
Old 08-10-2014, 10:12 AM   #3
Wayne Scraba
Liked 186 Times in 48 Posts
Smile Re: SS GT S-10 headers
Lemons Headers has them. Pricey, but apparently good quality. I think you'll need the headers to setup the engine location though (at least that's what I gather from the website).
Wayne
Wayne Scraba is online now   Reply With Quote
Old 08-10-2014, 01:43 PM   #4
Dragsinger
Wayne, I have run Lemons on other cars and the fit is excellent, I will follow up. I also noted the engine location footnote and agree it would be wise to have headers bolted on before finalizing the motor plate tabs.
Larry Woodfin 471W
Old 08-10-2014, 05:26 PM   #5
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Larry… Check out Hedman part #'s 65854,65855,65856,65857 they are well constructed and cost effective. Maurice.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 08-10-2014, 07:07 PM   #6
Dragsinger
Maurice,
Thanks, I like value and will follow up.
Larry Woodfin 471W
Old 08-10-2014, 07:34 PM   #7
Dragsinger
Maurice,
With the fender well style what is the clearance situation with front tire?
Larry Woodfin 471W
Old 08-10-2014, 07:34 PM   #8
MAURICE BLENDHEIM
Larry…The different part #'s represent primary tube dimensions and steps as well as collector diameters. They are also compatible with port plates and fully tig welded with removable collectors. MB.
Old 08-10-2014, 07:39 PM   #9
MAURICE BLENDHEIM
Originally Posted by Dragsinger View Post
Maurice,
With the engine in the correct position, things should work out (26-27" tire). What front tire diameter were you planning? Drop spindles? Ride height? These are all a determining factor. MB.
Old 08-10-2014, 08:36 PM   #10
Dragsinger
front tire size is flexible, it will depend on available room. So far, I see photos of the Hedman and Lemon designs.
I like the under car exit of the Lemons. The Hedman would need some extensions to direct the exhaust rearward. They would stir too much Texas dirt if pointed downward
Larry Woodfin 471W
