Old 10-27-2007, 12:44 AM   #1
munster
Default A.O.D. Trans
Could anyone tell me how strong these tranys are say compared to the C4 or what kind of power they can manage. Considering one in a 5.0 mustang to do some brackett racing. Thanks.
munster is offline   Reply With Quote
Old 10-27-2007, 09:46 AM   #2
Earle Holt
Liked 4 Times in 1 Post
Default Re: A.O.D. Trans
My understanding is that they can be built to handle alot of HP, but are heavy and internally inefficient compared to the C-4.
Many put a one-piece input shaft in them because the stock two-piece unit is prone to breakage. You probably know this, but Lentech is the leading Co. that has developed the AOD.
I built one for the street years ago and it was great. I moved to a C-4 for the track and the car picked-up at least a couple of tenths. The unique part of using the trans is the shift pattern. To shift it manually, you have to make the 1-2 shift, then pull the shifter back to 1st...the trans will stay in second gear...then you shift again to make the 2-3 shift.
Earle Holt 1055 Stock
Earle Holt is offline   Reply With Quote
Old 10-27-2007, 01:02 PM   #3
munster
Thanks Earl I think I'll stick with the C4. That shift pattern wouldn't work to good with a ratchet shifter ah.
