Old 05-15-2014, 07:36 PM   #11
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Default Re: Sunoco offical fuel for 2015
Originally Posted by njk53 View Post
I stated in another thread Sunoco is the official fuel of IHRA and as I recall a gallon of purple at US 131 was reasonably priced around 8 bucks a gallon. I am tired of buying $12-14 dollar a gallon fuel anyway.
Purple at Bandimere is $9 a gallon.
Lane Weber
Old 11-25-2014, 02:32 AM   #12
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Thumbs up Re: Sunoco offical fuel for 2015
The official race fuel payed there contingency today for my class win at the pacific SportsNational I got a email from them a couple of weeks ago wanting the tax form and now I am payed,now I just need my manufacture to do the right thing. Good Job Sunoco
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 11-25-2014, 09:39 AM   #13
Mickey Whaley
what is the same as c-11 for sunoco
Mickey Whaley is offline   Reply With Quote
Old 11-25-2014, 10:47 AM   #14
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Mickey I don't think they have as many different grades of fuel that VP has. Purple or Blue are the two closest to what we use in Stock/Super Stock. I have used the Blue fuel and it ran the same as VP c-12. I always had problems at fuel check with the color or some other issue that the fuel check guys did not like the Sunoco so I went back to VP. Now that Sunoco is the official fuel of NHRA they might not give as much hassle at fuel check.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 11-25-2014, 11:41 AM   #15
John Dinkel
Liked 263 Times in 68 Posts
I Have used Sunocco Purple for years in my Max Wedge with 11 to 1 compression and never had it fail. I get a barrell delivered to my house when I need it.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 11-25-2014, 06:56 PM   #16
Tom Meyer
Liked 354 Times in 120 Posts
Right now Sunoco has no replacement for C11, from what I have heard comp pro stock and prostock MC will have to run Sunoco and late season testing has not been good. Will know after PRI if VP will have there own contingency out side of NHRA. Tom
Tom Meyer 5240 SS Stock ???
Old 11-25-2014, 07:50 PM   #17
FED 387
Liked 333 Times in 180 Posts
my understanding is Comp can run either VP or Sunoco fuels---Pro Stock Car & Pro Stock Motorcycle must run Sunoco fuel --- Sunoco fuels are mandatory only in those 2 classes--- that's unless things have changed --
as far s C-11 go to the website smithtex.com they break down many popular racing gasolines as to their characteristics so you might be able to clarify what is C-11 in the Sunoco line up=== otherwise I would contact Sunoco ask them what is their equivalent to C-11 FED387
Old 11-25-2014, 11:26 PM   #18
GarysZ24
GarysZ24's Avatar
Liked 242 Times in 95 Posts
Hi Lane,
Another reason I'm glad I moved to metro Phoenix....Purple at the Love's Gas Station, across I-10 from Wild Horse Pass Motorsports Park, is $7.49 a gallon, and I've been using it since I found out the gas station sold it...at the pump no less!!!!
Gary Hampton
'86 Z24,173 V6
CF/S #5824 (#78 in 2021)
Old 11-26-2014, 12:42 AM   #19
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
All stock/superstock can still use VP, no reason to be in a hurry to switch.
Dyno is online now   Reply With Quote
Old 11-27-2014, 11:34 AM   #20
Tom Meyer
Here is the spec sheet on Vp X16 and Sunoco max
(Typical Values)
Specific Gravity: .710 @ 60°F
Lead: Yes
Color: Red
Motor Octane: 114
R+M/2: 116
Research Octane: 118
Reid Vapor Pressure: 6 psi
Oxygen Content = None
Technical Details
Color
Red
Octane (R+M)/2
116
Research Octane
118
Motor Octane
114
Specific Gravity
0.712
Weight (lbs/gallon)
5.9
Reid Vapor Pressure
5.3
10% Evaporation
177
50% Evaporation
214
90% Evaporation
227
Stoichiometric Air/Fuel Ratio
15.2
Oxygen (weight%)
0
Ethanol (volume%)
0
HC Ratio
2.16
Lower Heating Value (Btu/Gallon)
111500
Lower Heating Value (Btu/Pound)
18900
Dielectric Constant
-0.8
Leaded
Yes
Applications
Oxidation Stability (min.) 1440+
Distillation:.
10% evap @ 155.7°F
50% evap @ 219.4°F
90% evap @ 254.3°F
E.P @ 384.0°F
Availability: Sealed Drums
