Old 02-04-2015, 03:46 PM   #1
R Hastings
Default Sunnen CV 616
Had to hone a block this morning. Regular operator home sick. It seemed that no mater what settings were used the auto feed wouldn't keep consistent pressure. pressure would back off unless I kept slight pressure on feed wheel with my hand. Rough hone using diamond stones. Any thoughts on what may be wrong.
R Hastings is offline   Reply With Quote
Old 02-05-2015, 09:44 AM   #2
carl hinkson
Liked 18 Times in 10 Posts
Default Re: Sunnen CV 616
If your using diamond stones you may have to adjust pressure feed wheel to a higher number.
carl hinkson is offline   Reply With Quote
Old 02-05-2015, 10:06 AM   #3
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I would say needed more pressure also.
Mike Taylor 3601
Old 02-05-2015, 09:07 PM   #4
R Hastings
Thanks for the replies. We tried adjusting the pressure wheel up to the max with no improvement. We also tried regular roughing stones with the same results. We are going to try the tech line for suggestions.
Randy Hastings
Old 02-06-2015, 10:29 AM   #5
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
Increase the feed under the head.
rickseeman is offline   Reply With Quote
