Old 03-10-2015, 10:37 AM   #11
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: SS 5.3 ls combo
Originally Posted by Henry S View Post
I didn't think with the longer stroke of the 5.3 that it would need to rpm that high.
You're kidding, right?
Old 03-11-2015, 09:50 AM   #12
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Those formulas make real world numbers on the superflow I use,stock configuration heads using stock valve locations and angles about 99% of time will make within 5 hp of formula.
When you get into raised runners,18 degrees etc, spread ports,big chief style etc. then they make more than calculated.
LS engines I don't have any dyno info on them,don't know if will just make calculation or more.
I always check head on flow bench when I know I will run a engine on dyno,so I know what hp to expect.
as example a small block i had heads went 275 @ 25'' calculates 594 made it made 596.
Mike Taylor 3601
Old 03-12-2015, 12:00 AM   #13
Adger Smith
Liked 880 Times in 311 Posts
Mike,
I have found the LS heads make more power than the formulas for traditional heads. More like RR and spread port heads. I have a fudge factor when doing LS engine models. I believe his concerns with the T-Body air flow are justified, but not as important as with traditional heads. I've never done a carb or injected restricted LS engine. The closest I done to a restricted one is a 5.7 bracket deal with a good 750.
Adger Smith (Former SS)
Old 03-12-2015, 09:36 AM   #14
Mike Taylor 3601
I thought LS may make a little more than formulas, with their valve angle and location.
I had fudge factor for big chief it was around +9% power over formula.
Mike Taylor 3601
Old 03-12-2015, 09:47 AM   #15
Henry S
Liked 19 Times in 7 Posts
Thanks everyone for the replies. I appreciate the knowledge sharing and helpful insight.
Henry S is offline   Reply With Quote
