Liked 974 Times in 310 Posts
What manufacturer sells the thinnest head gasket for a bb chevy 396?
Liked 1,909 Times in 427 Posts
If you can find them anywhere, GM made one around 0.028". I think the one Mr. Gasket makes is thicker. The only other choice is either dead soft copper from some place such as Hussey or SCE, or a Cometic.
Alan Roehrich 212A G/S |
Liked 484 Times in 160 Posts
Old # used to be 1131 MR G I recall. Bore was 4.37 though.
Liked 10 Times in 7 Posts
Glenn
I think I still have a set of GM ( I think .015 ) Steel gaskets. I will look in the morning and get the part # off of them. |
Liked 285 Times in 87 Posts
Glenn… I've been using the MR.GASKET 1131G they are .018 -.020 thick and coated. They are 4.370 Bore and economical. Hope this helps. MB.
Liked 334 Times in 181 Posts
GM # 14015351----steel shim .022 thickness -----4.250 bore----- STEEL HEADS ONLY------seal with alum spray paint-----re-torque after first heat cycle-- or look for LS-6 OEM gaskets ---also check quench area clearance very important!!!! FED 387
What FED 387 said, the #14015351 are the gaskets I have. Sorry I thought they were for a 396.
Mario |
Liked 99 Times in 49 Posts
Thanks to all that responded
Liked 280 Times in 139 Posts
GM# 3993890 would be the one you would want,.022 thick,small bore(4.125).Or old stock Victor equiv..The problem is they are hard to find,the Mr.G, Rocket, etc are all big bore generic BB. gsa612
