Old 07-11-2015, 12:51 AM   #51
THE LEGEND
Default Re: New to Stock - Buying an 85 Camaro G/H/I??
It's a good deal. Do you want to run 2-3 tenths under or 1 second under? If the answer is 1 second under get out the check book its gonna be expensive. If you just want to get in the game then its a good deal.
Now if you're interested I have a P/SA Cutlass 7-8 under for $14,000
THE LEGEND is offline   Reply With Quote
Old 07-11-2015, 02:11 PM   #52
davidhuff
Liked 120 Times in 42 Posts
Originally Posted by Allen Sherman View Post
Oh and in response to some other posts on this topic, from carb to pan for a 1.00 second under 305 with the absolute best parts available today all brand new there's no way you can build one for under $20,000...I'm talking dart block, top notch heads and intake, roller rockers, tool steel lifters, manley pro I beam rods, good pistons, the right ring set, etc...just being honest, the parts alone are over $15,000
And members talk and complain about the new stockers from the factory.
Dart Block
Top Notch Heads and IntakeI
Roller rockers
Tool Steel Lifters
Manley Pro I Beam Rods
High Dollar Pistons
Wow,these parts cost over $15,000?
Old 07-11-2015, 03:37 PM   #53
Ed Wright
Ed Wright's Avatar
Not the cost or parts in the new cars, it's the bogus low hp factors.
Ed Wright 4156 SS/JA
Old 07-11-2015, 03:45 PM   #54
Rick Leininger Jr.
Dart Block
Roller rockers
Tool Steel Lifters
High Dollar Pistons
And then some, if you're trying to run up front.
Rick Leininger Jr. is offline   Reply With Quote
Old 07-11-2015, 04:07 PM   #55
Greg Hill
Liked 279 Times in 68 Posts
Dart Block
Roller rockers
Tool Steel Lifters
High Dollar Pistons
There is no way those parts cost 15,000 for a small block Chevy. The block is around $1300, the rods about $600, pistons and rings $1200, roller rockers $300, don't know about tool steel lifters, we run Smith lifters which are around $700. That adds up to $3700 before the heads and intake. Let's allow $4300 for the heads and intake from Top Notch. Looks like 8k to me. I realize it takes more parts than that, cam, bearings, gaskets, oil pump, and assorted others. I bet you I could get an good engine builder I happen to know well to build a 1.10 under 305 for 12k with some really good stuff and would go right through tear down.
Greg Hill 4171 STK
Old 07-11-2015, 04:56 PM   #56
Signman
Liked 269 Times in 99 Posts
The next tenth is 10K at least if you already have the rest of the car sorted out.
Old 07-11-2015, 05:47 PM   #57
Allen Sherman
Banned
Liked 5 Times in 3 Posts
Not gonna get in a pissing match on here but here's the break down on parts cost:
Dart block all done, bored, honed, lifter bushed and race ready is $2500
Top notch heads and intake with valves, springs, head studs and guide plates $5000
Tool steel lifters top notch dlc coated from trend $1100
Roller rockers from comp, ultra pro magnum $500+
Metric ring set with ring spacers (best stuff) $1375
Manley pro I beam rods $1175
Cp stocker pistons $800-1000
Good crank is gonna run you $1000
And you still haven't bought pushrods, gaskets, timing set, bearings, timing cover, oil pan, carb, and all the little accesories. I build these for a living and buy the parts on a daily basis so I kinda know what it costs...and I also can gurantee mine will go "right through tear down" also...
Allen Sherman is offline   Reply With Quote
Old 07-11-2015, 08:40 PM   #58
HR9121
HR9121's Avatar
Wow! My little spare parts 6k motor is looking better all the time lol. Don't run too bad either.
James Williamson
W200 J/SA. SS/JA
Old 07-11-2015, 09:11 PM   #59
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
roller rockers from comp
Double that if you opt for the big studs, and install adjusters in the rockers...triple it if you can't do it yourself.....and I am jus talking about the rockers
Bill Diehl is offline   Reply With Quote
Old 07-11-2015, 10:42 PM   #60
Dave Gantz
Liked 251 Times in 125 Posts
Wow. Definitely not the Stock Eliminator I was attracted to in the 70's!
