Old 10-14-2015, 04:47 PM   #31
mopar68
mopar68's Avatar
Liked 44 Times in 27 Posts
Default Re: 1970 NHRA National Record Holders
Al Corda
1964 Plymouth Belvedere Wagon { 426 / 410 HP 'Max-Wedge' }
E/SA..............11.94 @ 115.22 MPH
* Never saw one on a 'Plymouth Dealership Lot'.......
Old 10-15-2015, 02:41 PM   #32
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: 1970 NHRA National Record Holders
Originally Posted by Rich Biebel View Post
I am and have been pretty actively racing since 1980 in a lot of different cars and classes.
Started in 1966 so next year will mark 50 years since I started racing!
I migrated away from Stock/Super Stock many years ago but have had a couple stockers over the years...
Ah yes,,, I see your name on the H/S record. Care to tell us about that car and combo?
Danny Durham
Old 10-15-2015, 04:13 PM   #33
Max Wedge Wagon??
Old 10-16-2015, 08:18 AM   #34
TOM KASCH
Liked 241 Times in 100 Posts
1970 class winners , other to big to upload.
Name:	1970 INDY STK auto Class winners.jpg
Old 10-16-2015, 08:27 AM   #35
Old 10-16-2015, 03:52 PM   #36
TOM KASCH
May 1970 SS class records:
Old 10-16-2015, 03:56 PM   #37
TOM KASCH
1970 INDY SS class winners:
Old 10-16-2015, 07:03 PM   #38
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Danny Durham
1968 Chevy II ....Teal Blue....
350/295 Muncie 4 speed...2.5 first and 4.88's
Schiefer PP with a GM disc...Hurst super shifter...Hooker Headers.
Lakewood bars....M&H tires...7" on 4" wide wheels....air pressure was very low but that was what many of us did to get traction...
Made for a very uncomfortable ride sometimes at 112-113MPH
T/K built engine.....We re-rung it ourselves at Tony Feil's....after 1 season...
Pistons were Forgedtru's.....popular back then......
Tried about 3 cams.....
I preferred the Lunati over 2 other GK's.....
The Lunati could run more rpm without floating the valves.
Stock springs had about 84lbs on the seat....!
Had a lot of trouble keeping a trans in good shifting condition......stock syncros did not like missed gears....One miss and that was not good....
Springs went away and 2 MPH's were gone.....
Was hard to hook in poor traction conditions with that trans and rear gear.
Changing transmission first gear and maybe flywheel and or rear gear would have helped in mid summer on poor traction...
We had no benefit from concrete.....most tracks were asphalt and traction was limited...
All stick cars spun off the line a little....on a real bad track it spun a lot....
On a real good track you could bog it......Was very touchy..........I never stopped working on it or fixing it and we did not have much of a budget
Trans....valve springs....trying different crazy setups with the slapper bars.....all added up to working on it practically every night at the gas station I worked at....
Setting that record and winning Stock Eliminator at 2 different tracks on the same weekend was a couple high points with it....
We intended to assemble it with an automatic trans at first...
We thought a Turbo was going to be allowed....it was not...P/G only
I just hated P/G's back then and thought they would never work.....!
WRONG !!!
Bernie Agaman put the same type car together and it ran very well right away.....with the P/G. Ran as fast as the Mopars of the era that ruled the class......
We would have been way better off had we ran it with a P/G.....
Hindsight is 20-20
Rich Biebel
S/C 1479
Stock 147R
Old 10-17-2015, 05:54 AM   #39
Paul Ceasrine
Liked 10 Times in 10 Posts
WRONG !!!
Hindsight is 20-20
Rich,
Which Mopars were running in H/Stock in the {10.50 to 10.99 Wt/HP Class} that were competitive.
Old 10-17-2015, 09:24 AM   #40
Rich Biebel
If my memory is correct the 383/343 wagons ran H/SA back then.
Joe Kenny and others ran them....
Rich Biebel
S/C 1479
Stock 147R
