Old 11-02-2015, 01:05 PM   #11
Rich67stang
Liked 116 Times in 27 Posts
Default Re: 302 ford intake advise
Parker intake with a 4 hole 1" tapered spacer...Better plenum than a Victor JR.
Richard Preiser
1613 FGT/I 1510 C/SA 161 F/DA
Rich67stang is offline   Reply With Quote
Old 11-02-2015, 01:15 PM   #12
Mark Ugrich
Liked 71 Times in 38 Posts
Originally Posted by casrak7 View Post
Mark.....do you have any incrementals?
I probably have them buried somewhere. If I can find them I'll post it for you.
Old 11-02-2015, 03:02 PM   #13
Rory McNeil
Originally Posted by 68Coupe View Post
Rory
was wondering if you could give more specs on the cam you ran in your 331
Sure, Comp Cams FS 290B-6, Int. lift .576", Exh. .570" 106 lobe sep.,
Int. dur @ .050 255, exh.266.
After 5 years, the cam and lifters look great, so they will be going back in a new block.
NHRA 6390 STK
M/S 85 Mustang
Old 11-03-2015, 10:21 AM   #14
Lou Jeffery
I ran a Victor jr. on my 270 hp 302 crate motor and it ran pretty good. I did have a few drivability issues like stumbly running in the water and staging. I installed a Performer RPM air gap dual plane and it cured any issue I had plus picked up about five hundredths overall and much easier to drive. This combo uses a .498 lift hydraulic roller and a GT40P head. Went 11.40s at 111mph @2930 lbs.
Lou Jeffery is offline   Reply With Quote
Old 11-04-2015, 12:48 AM   #15
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
On the Dyno, My Crate Motor 302/270 liked the Victor JR w/ a 1" spacer. and Although the 750 made a touch more peak HP, a smaller carb made better average TQ and HP throughout the range
Here is a fun 331 built at the local racing engine shop. With the exception of the AFR's , a budget build, stock unfilled block, Cast scat crank , scat rods etc.. Victor JR, and Dave insisted on the Demon carb..
Enjoy,
https://www.youtube.com/channel/UC69...revJlEXyJH9k9w
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 11-06-2015, 02:38 AM   #16
casrak7
Liked 3 Times in 2 Posts
can you give me details of this crate motor? auto or stick ? and how much converter and what trans if auto? thanks!!
casrak7 is offline   Reply With Quote
