Old 12-15-2015, 12:49 PM   #1
R. Thorne
Liked 107 Times in 35 Posts
Default Racing seats
Trying to decide on polyethylene (jegs or summit)or aluminum Kirkey style seats. Big difference in price. Are the poly seats that inferior to aluminum? There appears to be no Sema type spec on seats, so, any "aftermarket" seats are legal? Anybody have any "real world" experience with the poly seats? Thanks, Ron.
R. Thorne is offline   Reply With Quote
Old 12-15-2015, 01:26 PM   #2
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Racing seats
I prefer the Jaz aluminum seat over Kirkey.
Old 12-15-2015, 01:30 PM   #3
Mickey Whaley
kirkey just measure your azz and go a little bigger
Mickey Whaley is offline   Reply With Quote
Old 12-15-2015, 01:44 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Ron,
You might search this topic as it was beat to death when stock was allowed to use aftermarket seats. Someone pointed out the steel inserts in the plastic seats as a concern if I recall. If you have noticed looking at the cars at the races the majority have Kirkey installed. Being able to brace the seat and also fasten it to the car favors an aluminum seat in my opinion. Due to the seat being a lot thinner compared to a factory seat, bracing will be mandatory.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-15-2015, 02:42 PM   #5
CMcAllister
Liked 926 Times in 263 Posts
This is a Chevelle with a pair of Jaz seats installed. Seat mounts are fabed out of CM tubing. They look like they're laid way back but the car owner and I both like this location for head room, leg room and distance to the pedals and wheel, comfort and vision. I like the Jaz seats, they are more compact than the Kirkey. The seat belt slots are not always in the optimum location, but having to modify that would not prevent me from using this seat. We lost about 80 pounds by replacing factory buckets and tracks with this set up.
Old 12-15-2015, 02:59 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,967 Times in 595 Posts
I have the poly seats in my car. I have them through bolted and did not use the threaded inserts for mounting. They are not as pretty as the aluminum but are very comfortable and light.
Mike Pearson 2485 SS
Old 12-15-2015, 03:03 PM   #7
Ed Wright
Ed Wright's Avatar
That is what I still have in mine. Through bolted as well. Much more comfortable to me, and light.
Ed Wright 4156 SS/JA
Old 12-15-2015, 07:03 PM   #8
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I run the JAZ poly seats in my car, and have them through bolted. The back of the seats are bolted to a brace fabed off my cage. The seats are very comfortable, and rock solid.
Old 12-16-2015, 11:52 AM   #9
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
I doubt you want to spend this much but they say if you wreck, these are good
http://racetech-usa.com/shop/seats
rickseeman is offline   Reply With Quote
Old 12-16-2015, 03:03 PM   #10
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
If you are tall stay away from any of the poly seats. The aluminum ones give you more head room by a few inches.
sst7250 is offline   Reply With Quote
