Old 01-15-2016, 11:23 AM   #1
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default Roller Cams in Stock Eliminator?
Is this going too happen? Is it or has it been discussed? I am starting to build my motor might need new lifters so before i spend money..
Thanks, any feedback appreaciated.
Will Lamprecht Div. 1 I/SA 396/325 65 Impala in progress
Old 01-15-2016, 01:24 PM   #2
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: Roller Cams in Stock Eliminator?
Roller cams in stock (older cars) have been proposed, asked for, begged for, pleaded for, and whatever else for, but to no avail. Flat lifters on older motors have been an issue and a costly one when a problem occurs, but as far as I know NHRA has not responded positively. Maybe someone knows better than me. I hope so. Flat lifters left the gate 30 or so years ago.
Jeff Teuton 4022 STK
Old 01-15-2016, 01:27 PM   #3
richie 2
Liked 205 Times in 93 Posts
x 2.
Old 01-15-2016, 01:46 PM   #4
Bruce Noland
Liked 444 Times in 145 Posts
Nope, for non roller motors.
Bruce Noland 1788 STK
Old 01-15-2016, 01:52 PM   #5
Charley Downing
Liked 653 Times in 89 Posts
If you gentlemen would like roller lifters I would suggest running Superstock. That class has all the stuff stocker dream of.
I believe it's called stock eliminator for a reason
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 01-15-2016, 02:08 PM   #6
Maybe so CB, but maybe for not such a good reason.
I have a friend who no longer posts here, who proposed $200 solid lifters for Stock, years ago. Not much interest there, at that time.
But, now we have $800 ceramic bottom lifters, $400 tool steel ones, all with only .015 thou travel, which are completely legal.
Plus now I'm told you need the ceramic ones to break in the tool steel ones..
Makes you wonder who thinks these rules up sometimes.
No ,I'm not advocating roller retrofits in Stock .
My thoughts are...if you want these items, just build a car that comes with them.
Of course that goes for a lot of stuff already made legal to use, too.
Old 01-15-2016, 02:26 PM   #7
impstocker
impstocker's Avatar
My Shubecks got rusty sitting in the shed with the rest of my 396 I ran in 2003, don't know if I can clean up.
As far as "stock" Stock Eliminator that all changed with the cam duration rule way back.
A roller cam and lifters would be cheaper than what we need to get now..
Will
Old 01-15-2016, 02:43 PM   #8
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Will
It was valve spring rule, not the camshaft rule.
Old 01-15-2016, 03:08 PM   #9
Mike Pearson
Mike Pearson's Avatar
Liked 1,945 Times in 586 Posts
Good roller lifters that will last are not cheap either. Inexpensive solid roller lifters will not hold up any better than the tool steel lifters with the light valve springs used on a stock eliminator engine. They will up the RPM range and then on to the next problem.
Mike Pearson 2485 SS
Old 01-15-2016, 03:43 PM   #10
Allen Sherman
Banned
Liked 5 Times in 3 Posts
Mark if you have a place where I can get tool steel
Lifters for $400 please give me there info, I'm assuming these aren't the DLC coated ones though...thanks
Allen Sherman is offline   Reply With Quote
