Old 01-15-2016, 04:37 PM   #11
john ancona
john ancona's Avatar
Liked 186 Times in 57 Posts
Default Re: Roller Cams in Stock Eliminator?
Originally Posted by Charley Downing View Post
If you gentlemen would like roller lifters I would suggest running Superstock. That class has all the stuff stocker dream of.
I believe it's called stock eliminator for a reason
Every time the subject of roller lifters for stock, someone suggest running Superstock ,It appears that there were a number of gentleman that wanted these changes over the past 30 years, Aftermarket Heads, Intake, Pistons ,Push Rods, Valves, Camshaft, Valve Springs, Retainers, Connecting Rods, Piston Rings, Crank Shaft, Engine Block, Oil Pan, Lifters, Roller Rockers, etc., Aftermarket parts have helped every body in stock eliminator achieve performance gains as well as durability along with a alternative to in some cases 50 year old OEM parts . Who will be the first to go back to the OEM parts and get run over (Flattened) or worse have their engine explode !
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
Old 01-15-2016, 05:21 PM   #12
Originally Posted by Allen Sherman View Post
Mark if you have a place where I can get tool steel
Lifters for $400 please give me there info, I'm assuming these aren't the DLC coated ones though...thanks
Allen, Trend , SBC last spring, $20 some odd dollars a piece ..Not coated.
So they need to be coated then ,too? ...Further making my point.
Old 01-15-2016, 06:16 PM   #13
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
From the comments, glad running Pure Stock...!
Lot of racers having a tough time with 8000rpm flat tappet hydraulic lifters.
What about a limit on Valve Spring Pressure.
Saying that!
What would make common sense?
or
Should racers be doing that anyway?
Dan
Old 01-15-2016, 06:24 PM   #14
Jeff Teuton
Liked 325 Times in 50 Posts
OK, roller rockers, any spring, almost any cam, any valve job, any anything, but lets keep them old lifters and let everyone buy 1200 bucks tool steel lifters instead of a hydraulic roller conversion for about a quarter. I already got mine. I want everyone to share in the treasure.
Jeff Teuton 4022 STK
Old 01-15-2016, 06:39 PM   #15
Bob Don
Bob Don's Avatar
Liked 905 Times in 193 Posts
There hasn't been too much "stock" about Stock Eliminator for quite a while now. Jus sayin'...
Bob Don 128 SS
Old 01-15-2016, 06:40 PM   #16
Dwight Southerland
Dwight Southerland's Avatar
Liked 782 Times in 195 Posts
Limiting valve spring pressure makes way too much sense and is way too simple. Let's gouge on everybody some more.
Old 01-15-2016, 07:03 PM   #17
Billy Nees
^^^^^^^^^^^^^^What Dwight Said!^^^^^^^^^^^^^^^^
Billy Nees 1188 STK, SS
Old 01-15-2016, 07:36 PM   #18
Lee Valentine
Liked 319 Times in 68 Posts
Dwight's right. I made my LT-1 stocker in to a super stocker two years ago, sure the initial investment was a bit, but only about two or three thousand dollars more than my last stocker engine. I just freshened it and it was cheaper than freshening the stocker engine.
Lee Valentine 1661 STK
Old 01-15-2016, 08:37 PM   #19
DODGEBOY
Liked 4 Times in 1 Post
how about quick fuel carburetors for my mopar the chevy have them and holley still makes the replancement 4 corner idle better metering blocks better boosters and more
DODGEBOY is offline   Reply With Quote
Old 01-15-2016, 08:44 PM   #20
Frank Castros
Liked 2,741 Times in 967 Posts
All this, and no battery in the trunk.
